[SOLVED] Monitor/Camera seems to be working but no video in console
AlphaJ
Post by AlphaJ »
Hi there. I'm new to both Linux and ZoneMinder. I recently purchased an MSI Cubi mini-PC to monitor my three IP security cams. It's a relatively low powered device so I liked the idea of running a thin Ubuntu server OS with ZoneMinder as the surveillance software.
I got Ubuntu server installed with no issues. For ZoneMinder, I used the instructions I found on the wiki (https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way). Everything went smoothly. ZoneMinder actually seems to be working well with one annoying problem.
After configuring my first camera (source type = ffmpeg) I noticed the ZoneMinder console won't display the video. The IP for the monitor is green on the console. It's logging events. If I drill into the frames for one of the events I can pull up still images from the camera. Just no video. On any page where I'm supposed to see video I see the little Chrome "I can't find your image" image. Here's a screenshot: https://gyazo.com/07a8fd5ffe9f5e6937b43631eef6d61f
Based on some other threads I found here I'm guessing this is some sort of Apache path configuration problem. I just don't know where to start.
I see a lot of the error below in the log.
"getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-481516s.sock ) failed: No such file or directory - checkStreamForErrors()"
Any help is very much appreciated. Thanks!
Date/Time
Component	Server	PID	Level	Message	File	Line
2016-04-12 20:17:06.440264	zma_m2		9897	WAR	Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size	zm_monitor.cpp	1315
2016-04-12 20:17:06.282242	zmc_m2		10117	ERR	Unable to open input rtsp://admin:fanfortagmanuse@192.168.1.4:80/live/0/h264.sdp due to: Operation now in progress	zm_ffmpeg_camera.cpp	271
2016-04-12 20:17:06.277142	zmc_m2		10115	WAR	Buffer overrun at index 13, image 112813, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:06.229790	zmc_m2		10115	WAR	Buffer overrun at index 13, image 112763, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:06.051694	zmc_m2		10115	WAR	Last image read from shared memory 1 seconds ago, zma may have gone away	zm_monitor.cpp	3106
2016-04-12 20:17:06.050348	zmc_m2		10115	WAR	Buffer overrun at index 26, image 112526, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:06.014055	zmc_m2		10115	WAR	Buffer overrun at index 26, image 112476, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.975555	zmc_m2		10115	WAR	Buffer overrun at index 26, image 112426, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.908681	zmc_m2		10115	WAR	Buffer overrun at index 33, image 112333, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.858553	zmc_m2		10115	WAR	Buffer overrun at index 33, image 112283, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.820855	zmc_m2		10115	WAR	Buffer overrun at index 33, image 112233, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.762032	zmc_m2		10115	WAR	Buffer overrun at index 33, image 112183, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.725707	zmc_m2		10115	WAR	Buffer overrun at index 33, image 112133, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.683315	zmc_m2		10115	WAR	Buffer overrun at index 28, image 112078, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.587244	zmc_m2		10115	WAR	Buffer overrun at index 28, image 112028, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.565984	zmc_m2		10115	INF	Driveway: 112000 - Capturing at 1000.00 fps	zm_monitor.cpp	3131
2016-04-12 20:17:05.549655	zmc_m2		10115	WAR	Buffer overrun at index 28, image 111978, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.513349	zmc_m2		10115	WAR	Buffer overrun at index 28, image 111928, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.474839	zmc_m2		10115	WAR	Buffer overrun at index 28, image 111878, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.417318	zmc_m2		10115	WAR	Buffer overrun at index 48, image 111798, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.381049	zmc_m2		10115	WAR	Buffer overrun at index 48, image 111748, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.344159	zmc_m2		10115	WAR	Buffer overrun at index 48, image 111698, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.307928	zmc_m2		10115	WAR	Buffer overrun at index 48, image 111648, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.271655	zmc_m2		10115	WAR	Buffer overrun at index 48, image 111598, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.231779	zmc_m2		10115	WAR	Buffer overrun at index 48, image 111548, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.058724	zmc_m2		10115	WAR	Last image read from shared memory 1 seconds ago, zma may have gone away	zm_monitor.cpp	3106
2016-04-12 20:17:05.055306	zmc_m2		10115	WAR	Buffer overrun at index 30, image 111380, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:05.012783	zmc_m2		10115	WAR	Buffer overrun at index 30, image 111330, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.974624	zmc_m2		10115	WAR	Buffer overrun at index 30, image 111280, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.937168	zmc_m2		10115	WAR	Buffer overrun at index 29, image 111229, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.890857	zmc_m2		10115	WAR	Buffer overrun at index 29, image 111179, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.850652	zmc_m2		10115	WAR	Buffer overrun at index 29, image 111129, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.806533	zmc_m2		10115	WAR	Buffer overrun at index 29, image 111079, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.770373	zmc_m2		10115	WAR	Buffer overrun at index 29, image 111029, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.748445	zmc_m2		10115	INF	Driveway: 111000 - Capturing at 1000.00 fps	zm_monitor.cpp	3131
2016-04-12 20:17:04.732810	zmc_m2		10115	WAR	Buffer overrun at index 29, image 110979, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.677948	zmc_m2		10115	WAR	Buffer overrun at index 24, image 110924, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.631878	zmc_m2		10115	WAR	Buffer overrun at index 24, image 110874, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.595748	zmc_m2		10115	WAR	Buffer overrun at index 24, image 110824, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.549757	zmc_m2		10115	WAR	Buffer overrun at index 24, image 110774, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.498160	zmc_m2		10115	WAR	Buffer overrun at index 24, image 110724, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.396803	zmc_m2		10115	WAR	Buffer overrun at index 34, image 110634, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.313932	zmc_m2		10115	WAR	Buffer overrun at index 34, image 110584, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.303146	zma_m1		9168	INF	Valdosta: 70440 - Left alarm state (13) - 9455(694) images	zm_monitor.cpp	1702
2016-04-12 20:17:04.262417	zmc_m2		10115	WAR	Buffer overrun at index 34, image 110534, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.225206	zmc_m2		10115	WAR	Buffer overrun at index 34, image 110484, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.099659	web_js		9132	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-481516s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2016-04-12 20:17:04.088998	web_php		9132	ERR	socket_sendto( /var/run/zm/zms-481516s.sock ) failed: No such file or directory	/usr/share/zoneminder/www/includes/functions.php	2371
2016-04-12 20:17:04.088079	zmc_m2		10115	WAR	Last image read from shared memory 1 seconds ago, zma may have gone away	zm_monitor.cpp	3106
2016-04-12 20:17:04.087555	zmc_m2		10115	WAR	Buffer overrun at index 47, image 110297, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:04.024880	zmc_m2		10115	WAR	Buffer overrun at index 47, image 110247, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.988619	zmc_m2		10115	WAR	Buffer overrun at index 47, image 110197, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.938163	zma_m2		9897	INF	Driveway: 86000 - Analysing at 41.67 fps	zm_monitor.cpp	1287
2016-04-12 20:17:03.910981	zmc_m2		10115	WAR	Buffer overrun at index 10, image 110110, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.874664	zmc_m2		10115	WAR	Buffer overrun at index 10, image 110060, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.838514	zmc_m2		10115	WAR	Buffer overrun at index 10, image 110010, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.829202	zmc_m2		10115	INF	Driveway: 110000 - Capturing at 1000.00 fps	zm_monitor.cpp	3131
2016-04-12 20:17:03.800831	zmc_m2		10115	WAR	Buffer overrun at index 10, image 109960, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.764354	zmc_m2		10115	WAR	Buffer overrun at index 10, image 109910, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.727393	zmc_m2		10115	WAR	Buffer overrun at index 10, image 109860, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.687545	zma_m2		9897	WAR	Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size	zm_monitor.cpp	1315
2016-04-12 20:17:03.624667	zmc_m2		10115	WAR	Buffer overrun at index 11, image 109761, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.582055	zmc_m2		10115	WAR	Buffer overrun at index 11, image 109711, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.545161	zmc_m2		10115	WAR	Buffer overrun at index 11, image 109661, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.500346	zmc_m2		10115	WAR	Buffer overrun at index 11, image 109611, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.418870	zmc_m2		10115	WAR	Buffer overrun at index 42, image 109542, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.377590	zma_m1		9168	INF	Valdosta: 70415 - Gone into alert state	zm_monitor.cpp	1695
2016-04-12 20:17:03.366873	zmc_m2		10115	WAR	Buffer overrun at index 42, image 109492, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.353054	zma_m1		9168	INF	Valdosta: 70414 - Gone into alarm state	zm_monitor.cpp	1605
2016-04-12 20:17:03.278340	zmc_m2		10115	WAR	Buffer overrun at index 42, image 109442, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.223536	zmc_m2		10115	WAR	Buffer overrun at index 42, image 109392, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.053584	zmc_m2		10115	WAR	Last image read from shared memory 1 seconds ago, zma may have gone away	zm_monitor.cpp	3106
2016-04-12 20:17:03.052111	zmc_m2		10115	WAR	Buffer overrun at index 3, image 109153, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:03.008370	zmc_m2		10115	WAR	Buffer overrun at index 3, image 109103, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.935638	zmc_m2		10115	WAR	Buffer overrun at index 3, image 109053, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.899405	zmc_m2		10115	WAR	Buffer overrun at index 3, image 109003, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.895895	zmc_m2		10115	INF	Driveway: 109000 - Capturing at inf fps	zm_monitor.cpp	3131
2016-04-12 20:17:02.862395	zmc_m2		10115	WAR	Buffer overrun at index 3, image 108953, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.825017	zmc_m2		10115	WAR	Buffer overrun at index 3, image 108903, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.778416	zmc_m2		10115	WAR	Buffer overrun at index 3, image 108853, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.722504	zmc_m2		10115	WAR	Buffer overrun at index 3, image 108803, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.651803	zmc_m2		10115	WAR	Buffer overrun at index 16, image 108716, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.615427	zmc_m2		10115	WAR	Buffer overrun at index 16, image 108666, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.557628	zmc_m2		10115	WAR	Buffer overrun at index 16, image 108616, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.512768	zmc_m2		10115	WAR	Buffer overrun at index 16, image 108566, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.475543	zmc_m2		10115	WAR	Buffer overrun at index 16, image 108516, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.427113	zmc_m2		10115	WAR	Buffer overrun at index 9, image 108459, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.390778	zmc_m2		10115	WAR	Buffer overrun at index 9, image 108409, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.338448	zmc_m2		10115	WAR	Buffer overrun at index 9, image 108359, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.302299	zmc_m2		10115	WAR	Buffer overrun at index 9, image 108309, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.265829	zmc_m2		10115	WAR	Buffer overrun at index 9, image 108259, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.226303	zmc_m2		10115	WAR	Buffer overrun at index 9, image 108209, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.047417	zmc_m2		10115	INF	Driveway: 108000 - Capturing at 1000.00 fps	zm_monitor.cpp	3131
2016-04-12 20:17:02.044938	zmc_m2		10115	WAR	Last image read from shared memory 1 seconds ago, zma may have gone away	zm_monitor.cpp	3106
2016-04-12 20:17:02.044387	zmc_m2		10115	WAR	Buffer overrun at index 46, image 107996, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:02.007219	zmc_m2		10115	WAR	Buffer overrun at index 46, image 107946, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.968535	zmc_m2		10115	WAR	Buffer overrun at index 46, image 107896, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.901674	zmc_m2		10115	WAR	Buffer overrun at index 3, image 107803, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.865485	zmc_m2		10115	WAR	Buffer overrun at index 3, image 107753, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.828494	zmc_m2		10115	WAR	Buffer overrun at index 3, image 107703, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.792210	zmc_m2		10115	WAR	Buffer overrun at index 3, image 107653, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.755990	zmc_m2		10115	WAR	Buffer overrun at index 3, image 107603, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.718030	zmc_m2		10115	WAR	Buffer overrun at index 3, image 107553, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.666680	zmc_m2		10115	WAR	Buffer overrun at index 47, image 107497, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.588619	zmc_m2		10115	WAR	Buffer overrun at index 47, image 107447, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.551550	zmc_m2		10115	WAR	Buffer overrun at index 47, image 107397, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.512861	zmc_m2		10115	WAR	Buffer overrun at index 47, image 107347, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.473388	zmc_m2		10115	WAR	Buffer overrun at index 47, image 107297, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.397338	zmc_m2		10115	WAR	Buffer overrun at index 49, image 107199, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.344235	zmc_m2		10115	WAR	Buffer overrun at index 49, image 107149, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.294156	zmc_m2		10115	WAR	Buffer overrun at index 49, image 107099, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.225228	zmc_m2		10115	WAR	Buffer overrun at index 49, image 107049, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.179240	zma_m2		9897	WAR	Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size	zm_monitor.cpp	1315
2016-04-12 20:17:01.178932	zmc_m2		10115	INF	Driveway: 107000 - Capturing at 1000.00 fps	zm_monitor.cpp	3131
2016-04-12 20:17:01.058589	zmc_m2		10115	WAR	Last image read from shared memory 1 seconds ago, zma may have gone away	zm_monitor.cpp	3106
2016-04-12 20:17:01.057718	zmc_m2		10115	WAR	Buffer overrun at index 31, image 106831, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:01.020333	zmc_m2		10115	WAR	Buffer overrun at index 31, image 106781, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.971319	zmc_m2		10115	WAR	Buffer overrun at index 31, image 106731, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.901857	zmc_m2		10115	WAR	Buffer overrun at index 8, image 106658, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.865502	zmc_m2		10115	WAR	Buffer overrun at index 8, image 106608, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.826180	zmc_m2		10115	WAR	Buffer overrun at index 8, image 106558, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.775024	zmc_m2		10115	WAR	Buffer overrun at index 8, image 106508, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.729128	zmc_m2		10115	WAR	Buffer overrun at index 8, image 106458, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.669896	zmc_m2		10115	WAR	Buffer overrun at index 2, image 106402, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.623028	zmc_m2		10115	WAR	Buffer overrun at index 2, image 106352, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.586468	zmc_m2		10115	WAR	Buffer overrun at index 2, image 106302, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.534108	zmc_m2		10115	WAR	Buffer overrun at index 2, image 106252, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.496380	zmc_m2		10115	WAR	Buffer overrun at index 2, image 106202, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.460077	zmc_m2		10115	WAR	Buffer overrun at index 2, image 106152, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.424105	zma_m2		9897	WAR	Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size	zm_monitor.cpp	1315
2016-04-12 20:17:00.423623	zmc_m2		10115	WAR	Buffer overrun at index 3, image 106103, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.385821	zmc_m2		10115	WAR	Buffer overrun at index 3, image 106053, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.321484	zmc_m2		10115	WAR	Buffer overrun at index 3, image 106003, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.317249	zmc_m2		10115	INF	Driveway: 106000 - Capturing at 1000.00 fps	zm_monitor.cpp	3131
2016-04-12 20:17:00.283946	zmc_m2		10115	WAR	Buffer overrun at index 3, image 105953, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.247671	zmc_m2		10115	WAR	Buffer overrun at index 3, image 105903, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.209002	zmc_m2		10115	WAR	Buffer overrun at index 3, image 105853, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.072102	zmc_m2		10115	WAR	Last image read from shared memory 1 seconds ago, zma may have gone away	zm_monitor.cpp	3106
2016-04-12 20:17:00.071337	zmc_m2		10115	WAR	Buffer overrun at index 24, image 105674, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:17:00.033996	zmc_m2		10115	WAR	Buffer overrun at index 24, image 105624, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.997737	zmc_m2		10115	WAR	Buffer overrun at index 24, image 105574, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.959219	zmc_m2		10115	WAR	Buffer overrun at index 24, image 105524, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.899518	zmc_m2		10115	WAR	Buffer overrun at index 41, image 105441, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.853607	zmc_m2		10115	WAR	Buffer overrun at index 41, image 105391, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.806553	zmc_m2		10115	WAR	Buffer overrun at index 41, image 105341, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.764032	zmc_m2		10115	WAR	Buffer overrun at index 41, image 105291, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.724385	zmc_m2		10115	WAR	Buffer overrun at index 41, image 105241, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.673295	zma_m2		9897	WAR	Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size	zm_monitor.cpp	1315
2016-04-12 20:16:59.669664	zmc_m2		10115	WAR	Buffer overrun at index 42, image 105192, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.632346	zmc_m2		10115	WAR	Buffer overrun at index 42, image 105142, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.587693	zmc_m2		10115	WAR	Buffer overrun at index 42, image 105092, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.551228	zmc_m2		10115	WAR	Buffer overrun at index 42, image 105042, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.520141	zmc_m2		10115	INF	Driveway: 105000 - Capturing at 1000.00 fps	zm_monitor.cpp	3131
2016-04-12 20:16:59.513676	zmc_m2		10115	WAR	Buffer overrun at index 42, image 104992, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.458906	zmc_m2		10115	WAR	Buffer overrun at index 42, image 104942, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.390373	zmc_m2		10115	WAR	Buffer overrun at index 47, image 104847, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.337099	zmc_m2		10115	WAR	Buffer overrun at index 47, image 104797, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.314353	zma_m1		9168	INF	Valdosta: 70316 - Left alarm state (13) - 9331(693) images	zm_monitor.cpp	1702
2016-04-12 20:16:59.237169	zmc_m2		10115	WAR	Buffer overrun at index 47, image 104747, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.200732	zmc_m2		10115	WAR	Buffer overrun at index 47, image 104697, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.074044	zmc_m2		10115	WAR	Last image read from shared memory 1 seconds ago, zma may have gone away	zm_monitor.cpp	3106
2016-04-12 20:16:59.073435	zmc_m2		10115	WAR	Buffer overrun at index 20, image 104520, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:59.036595	zmc_m2		10115	WAR	Buffer overrun at index 20, image 104470, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.903057	zmc_m2		10115	WAR	Buffer overrun at index 5, image 104405, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.849021	zmc_m2		10115	WAR	Buffer overrun at index 5, image 104355, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.811798	zmc_m2		10115	WAR	Buffer overrun at index 5, image 104305, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.768985	zmc_m2		10115	WAR	Buffer overrun at index 5, image 104255, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.731414	zmc_m2		10115	WAR	Buffer overrun at index 5, image 104205, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.693711	zmc_m2		10115	WAR	Buffer overrun at index 5, image 104155, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.624702	zmc_m2		10115	WAR	Buffer overrun at index 9, image 104059, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.588877	zmc_m2		10115	WAR	Buffer overrun at index 9, image 104009, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.581176	zmc_m2		10115	INF	Driveway: 104000 - Capturing at 1000.00 fps	zm_monitor.cpp	3131
2016-04-12 20:16:58.552259	zmc_m2		10115	WAR	Buffer overrun at index 9, image 103959, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.516184	zmc_m2		10115	WAR	Buffer overrun at index 9, image 103909, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.479791	zmc_m2		10115	WAR	Buffer overrun at index 9, image 103859, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.443532	zmc_m2		10115	WAR	Buffer overrun at index 9, image 103809, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.407234	zma_m2		9897	WAR	Approaching buffer overrun, consider slowing capture, simplifying analysis or increasing ring buffer size	zm_monitor.cpp	1315
2016-04-12 20:16:58.406888	zmc_m2		10115	WAR	Buffer overrun at index 10, image 103760, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.370502	zmc_m2		10115	WAR	Buffer overrun at index 10, image 103710, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.334099	zmc_m2		10115	WAR	Buffer overrun at index 10, image 103660, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.295913	zmc_m2		10115	WAR	Buffer overrun at index 10, image 103610, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.251521	zmc_m2		10115	WAR	Buffer overrun at index 10, image 103560, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.215107	zmc_m2		10115	WAR	Buffer overrun at index 10, image 103510, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.203449	zma_m1		9168	INF	Valdosta: 70291 - Gone into alert state	zm_monitor.cpp	1695
2016-04-12 20:16:58.084305	zmc_m2		10115	WAR	Last image read from shared memory 1 seconds ago, zma may have gone away	zm_monitor.cpp	3106
2016-04-12 20:16:58.083579	zmc_m2		10115	WAR	Buffer overrun at index 37, image 103387, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:58.026992	zmc_m2		10115	WAR	Buffer overrun at index 37, image 103337, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.987830	zmc_m2		10115	WAR	Buffer overrun at index 37, image 103287, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.938809	zmc_m2		10115	WAR	Buffer overrun at index 37, image 103237, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.894138	zmc_m2		10115	WAR	Buffer overrun at index 33, image 103183, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.850564	zmc_m2		10115	WAR	Buffer overrun at index 33, image 103133, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.803400	zmc_m2		10115	WAR	Buffer overrun at index 33, image 103083, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.715345	zmc_m2		10115	WAR	Buffer overrun at index 33, image 103033, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.687686	zmc_m2		10115	INF	Driveway: 103000 - Capturing at 1000.00 fps	zm_monitor.cpp	3131
2016-04-12 20:16:57.591657	zmc_m2		10115	WAR	Buffer overrun at index 2, image 102952, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.543913	zmc_m2		10115	WAR	Buffer overrun at index 2, image 102902, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.504166	zmc_m2		10115	WAR	Buffer overrun at index 2, image 102852, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.456529	zmc_m2		10115	WAR	Buffer overrun at index 2, image 102802, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.346393	zmc_m2		10115	WAR	Buffer overrun at index 14, image 102714, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
2016-04-12 20:16:57.300509	zmc_m2		10115	WAR	Buffer overrun at index 14, image 102664, slow down capture, speed up analysis or increase ring buffer size	zm_monitor.cpp	3100
deanko
Re: Monitor/Camera seems to be working but no video in console
Post by deanko »
I am having the same issues after upgrading from zoneminder1.25 to 1.29 on ubuntu 14.04. No streaming and no video playback but I can view still images. I upgraded to 1.29 so zmninja on my phone would work, and it does! streaming and video playback work in zmninja on my phone. I will post if I find anything.
zamar17
Post by zamar17 »
@AlphaJ
Looking at your log, did you try to lower your Cam framerate through its own UI (not via ZoneMinder)?
lack of video is usually one of these:
The last step in the procedure:
Click on Options - Paths Change PATH_ZMS to /zm/cgi-bin/nph-zms (Caution: make sure you enter only /zm/cgi-bin/nph-zms with no space at the end or your video will not work!)
or
you do not have the resolution set right
Yes, there could be other factors but it has been proven time and again that if you follow those instructions Zoneminder will start and work! And, socket sendto "errors" may not really be an error....
AlphaJ
Post by AlphaJ »
bbunge, you're absolutely right. Somehow I completely overlooked the last step in the instructions. It worked as soon as I made that change.
Thanks so much for your help!
FvdLaar
Re: [SOLVED] Monitor/Camera seems to be working but no video in console
Post by FvdLaar »
Proves it's a webserver issue, not zoneminder issues!
