ERR: Received unexpected SDES item type 2
tazar
Post by tazar »
i've used zm for a few years now, for a small home installation with 4 samsung ip cameras, accessed by ffmpeg via a rtsp stream, 3 cameras in mocord mode, 1 in record.
Everything was - and is - working fine, until now, when i started playing with REMOTE input type in the attempt to save cpu on my old atom 330, 2gb ram.
Actually, cameras do work, and i can see the images, but i'm getting too many (100's in few min) of this errors Received unexpected SDES item type 2 filling the logs.
It is almost certainly something related to rtp stream, but i cant debug it any further.
Any suggestion, please?
Thank you
2016-04-04 01:41:36.517787	zmc_m5		1227	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:36.227546	zmc_m1		1187	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:35.227682	zmc_m1		1187	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:35.142429	zmc_m3		1210	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:35.034550	zmwatch		1267	INF	Watchdog pausing for 30 seconds	zmwatch.pl
2016-04-04 01:41:34.961120	zmwatch		1267	INF	Watchdog starting	zmwatch.pl
2016-04-04 01:41:34.572527	zma_m3		1263	INF	In mode 5/1, warming up	zma.cpp	142
2016-04-04 01:41:34.271350	undef		1263	INF	No Server ID or Name specified in config. Not using Multi-Server Mode.	zm_config.cpp	139
2016-04-04 01:41:34.235076	zmc_m1		1187	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:34.192320	zmdc		1127	INF	'zmwatch.pl' starting at 16/04/04 01:41:34, pid = 1267	zmdc.pl
2016-04-04 01:41:34.192260	zmdc		1267	INF	'zmwatch.pl' started at 16/04/04 01:41:34	zmdc.pl
2016-04-04 01:41:34.092240	zmdc		1263	INF	'zma -m 3' started at 16/04/04 01:41:34	zmdc.pl
2016-04-04 01:41:34.091810	zmdc		1127	INF	'zma -m 3' starting at 16/04/04 01:41:34, pid = 1263	zmdc.pl
2016-04-04 01:41:34.020050	zmfilter		1239	INF	Scanning for events	zmfilter.pl
2016-04-04 01:41:34.017150	zmdc		1127	INF	Starting pending process, zma -m 3	zmdc.pl
2016-04-04 01:41:33.515689	zmc_m2		1195	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:33.307863	zma_m1		1250	INF	In mode 5/1, warming up	zma.cpp	142
2016-04-04 01:41:33.223674	zmc_m1		1187	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:32.949424	zma_m2		1248	INF	In mode 4/1, warming up	zma.cpp	142
2016-04-04 01:41:32.865203	undef		1250	INF	No Server ID or Name specified in config. Not using Multi-Server Mode.	zm_config.cpp	139
2016-04-04 01:41:32.788610	zmdc		1252	INF	'zmaudit.pl -c' started at 16/04/04 01:41:32	zmdc.pl
2016-04-04 01:41:32.787980	zmdc		1127	INF	'zmaudit.pl -c' starting at 16/04/04 01:41:32, pid = 1252	zmdc.pl
2016-04-04 01:41:32.563960	zmdc		1250	INF	'zma -m 1' started at 16/04/04 01:41:32	zmdc.pl
2016-04-04 01:41:32.563570	zmdc		1127	INF	'zma -m 1' starting at 16/04/04 01:41:32, pid = 1250	zmdc.pl
2016-04-04 01:41:32.533999	undef		1248	INF	No Server ID or Name specified in config. Not using Multi-Server Mode.	zm_config.cpp	139
2016-04-04 01:41:32.510998	zma_m5		1236	INF	In mode 5/1, warming up	zma.cpp	142
2016-04-04 01:41:32.474070	zmdc		1127	INF	Starting pending process, zma -m 1	zmdc.pl
2016-04-04 01:41:32.331210	zmdc		1248	INF	'zma -m 2' started at 16/04/04 01:41:32	zmdc.pl
2016-04-04 01:41:32.331200	zmdc		1127	INF	'zma -m 2' starting at 16/04/04 01:41:32, pid = 1248	zmdc.pl
2016-04-04 01:41:32.208125	zmc_m1		1187	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:32.101360	zmdc		1127	INF	Starting pending process, zma -m 2	zmdc.pl
2016-04-04 01:41:31.544061	zmc_m5		1227	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:31.425816	zmc_m5		1227	INF	Received new Content-Base in DESCRIBE response header. Updated device Url to: 'rtsp://192.168.1.151:554/profile2/media.smp'	zm_rtsp.cpp	398
2016-04-04 01:41:31.420140	zmdc		1239	INF	'zmfilter.pl' started at 16/04/04 01:41:31	zmdc.pl
2016-04-04 01:41:31.419940	zmdc		1127	INF	'zmfilter.pl' starting at 16/04/04 01:41:31, pid = 1239	zmdc.pl
2016-04-04 01:41:31.387062	zma_m5		1236	WAR	Waiting for capture daemon	zm_monitor.cpp	503
2016-04-04 01:41:31.224096	undef		1236	INF	No Server ID or Name specified in config. Not using Multi-Server Mode.	zm_config.cpp	139
2016-04-04 01:41:31.207357	zmc_m1		1187	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:31.169467	zmc_m5		1225	INF	Starting Capture version 1.29.0	zmc.cpp	250
2016-04-04 01:41:31.052100	zmdc		1236	INF	'zma -m 5' started at 16/04/04 01:41:31	zmdc.pl
2016-04-04 01:41:31.042950	zmdc		1127	INF	'zma -m 5' starting at 16/04/04 01:41:31, pid = 1236	zmdc.pl
2016-04-04 01:41:30.985590	zmdc		1127	INF	Starting pending process, zma -m 5	zmdc.pl
2016-04-04 01:41:30.933790	zmdc		1127	ERR	'zma -m 5' exited abnormally, exit status 255	zmdc.pl
2016-04-04 01:41:30.873433	zma_m5		1229	ERR	Shared data not initialised by capture daemon for monitor corte	zm_monitor.cpp	442
2016-04-04 01:41:30.819868	undef		1229	INF	No Server ID or Name specified in config. Not using Multi-Server Mode.	zm_config.cpp	139
2016-04-04 01:41:30.612310	zmdc		1229	INF	'zma -m 5' started at 16/04/04 01:41:30	zmdc.pl
2016-04-04 01:41:30.609840	zmdc		1127	INF	'zma -m 5' starting at 16/04/04 01:41:30, pid = 1229	zmdc.pl
2016-04-04 01:41:30.358077	undef		1225	INF	No Server ID or Name specified in config. Not using Multi-Server Mode.	zm_config.cpp	139
2016-04-04 01:41:30.214173	zmc_m1		1187	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:30.186590	zmdc		1225	INF	'zmc -m 5' started at 16/04/04 01:41:30	zmdc.pl
2016-04-04 01:41:30.183810	zmdc		1127	INF	'zmc -m 5' starting at 16/04/04 01:41:30, pid = 1225	zmdc.pl
2016-04-04 01:41:30.172015	zmc_m3		1210	ERR	Received unexpected SDES item type 2, ignoring	zm_rtp_ctrl.cpp	127
2016-04-04 01:41:30.076660	zmdc		1127	INF	Starting pending process, zmc -m 5
Schermata 2016-04-04 alle 09.01.41.png (286.49 KiB) Viewed 1610 times
Schermata 2016-04-04 alle 09.02.22.png (294.31 KiB) Viewed 1610 times
Re: ERR: Received unexpected SDES item type 2
Use a source type of ffmpeg instead.
We simply don't have the resources ( read -> volunteers ) to give this any love when there is a suitable workaround which works much better.
