Cameras arent visibles after I activate authentication
evilside
Post by evilside » Fri Apr 01, 2016 8:11 pm
Hi
When I activate the Zoneminder Web console authentication, the cameras arent visibles.
I have restarted service after change but not working.
If I disable the authentication option, the cameras are inmediatly visibles.
I have Foscam IP cameras and I have writed the user and password camera in Remote Host Path, maybe this is the problem?
Re: Cameras arent visibles after I activate authentication
Post by bbunge » Fri Apr 01, 2016 9:26 pm
Did you give your user permission to view cameras?
evilside
Post by evilside » Fri Apr 08, 2016 12:12 am
Hi
Yes, the beginning, the cameras aren't selected in the list of restricted cameras, but now are marked, and occur same problem, the cameras are not visible.
This is admin user:
PacoLM
Post by PacoLM » Fri Apr 08, 2016 6:50 am
Stupid question...Have you logged out from the session and logged in again after the changes?
mini-ITX system (6 IPCams - Ubuntu14.04 - ZM1.31.1)
evilside
Post by evilside » Wed Apr 13, 2016 7:15 pm
...yes and restarted the zoneminder service.
Post by rockedge » Thu Apr 14, 2016 1:47 pm
Look in Options>Systems
AUTH_RELAY Method used to relay authentication information (?) hashed plain none
and select "none"
save restart zoneminder and see if that works.
evilside
Post by evilside » Wed Apr 20, 2016 4:12 pm
I have changed AUTH_RELAY from 'hashed' to 'plain' and now is working. Is secure use this method for Internet?
Post by rockedge » Thu Apr 21, 2016 9:41 pm
No it is not secure. Only the user name is passed in the URL for authentication. Have you changed AUTH_HASH_SECRET ? I have also had this occur. I then re-enabled the Hash auth and it worked. I can not say for sure what changed to make it work but now it does.
Post by knight-of-ni » Fri Apr 22, 2016 1:51 am
I have seen this occur with AUTH_HASH_IPS enabled.
For some reason, ZoneMinder could not determine the client's ip so it was null. I don't remember the circumstances which caused this.
evilside
Post by evilside » Wed Apr 27, 2016 7:36 pm
I changed AUTH_HASH_SECRET and disabled the AUTH_HASH_IPS option but not working the hashed auth relay, only with the PLAIN option is working.
jcconnell
Post by jcconnell » Sun Sep 11, 2016 12:18 am
Having the same issue here.
After enabling builtin auth, I cannot view cameras if using hashed auth_relay. Plain and None work.
I have tried various configurations of logging out, restarting ZM, disabling Auth_hash_ips, etc. No luck. I'm running 14.04 and ZM 1.30.
pat2
Post by pat2 » Sun Apr 07, 2019 8:10 am
I found a solution on 1.30.4, probably 2 and 3 are the more important:
1. cancel cookies and access grants in firefox for zm site,
2. run sudo dpkg-reconfigure tzdata and set your your time zone, e.g. America and then New_York
3, nano /etc/php/7.0/apache2/php.ini and set date.timezone = America/New_York
2 and 3 to be set to same timezone.
