Received RTCP_RR packet errors
kenworth
Post by kenworth »
Recently I have been seeing errors in the log of the form "Received RTCP_RR packet." These are coming from the one Axis camera I have on the network. Any idea what this means and why they are considered an error condition? The camera seems to be working fine.
Re: Received RTCP_RR packet errors
Could be that UDP packets are being dropped if you are using rtsp. You can force TCP by adding ?tcp to your souce line.
kenworth
Post by kenworth »
This camera is configured as RTP/RTSP, which from my understanding forces TCP.
Nope. What Axis camera?
kevin186
Post by kevin186 »
bbunge wrote:Could be that UDP packets are being dropped if you are using rtsp. You can force TCP by adding ?tcp to your souce line.
Does that force zoneminder to initiate a tcp connection or does it tell the ip cam to send data in tcp?
kenworth
Post by kenworth »
Camera is an Axis P3364-L
kenworth
Post by kenworth »
In any event, I have confirmed that this camera is streaming over TCP.
