Migrate ZM installation
Markymark
Post by Markymark »
after struggling to upgrade my Debian installation from Wheezy to Jessie prior to upgrade ZM from 1.28 to 1.29 I decided to start with a fresh Ubuntu Trusty / ZM 1.29 installation. Having a carefully tuned ZM installation up and running I would like to migrate the database / settings from the old installation. I thought about the following steps:
1. dump database (mysqldump)
2. transfer dump to new server
3. import database
4. run zmupdate.pl
Could somebody please confirm that this is - basically - the way to go?
Any hint apprechiated.
Regrds,
Mark
Re: Migrate ZM installation
5. Examine Options -> Paths and verify every value shown is appropriate for Ubuntu Trusty, particularly PATH_ZMS (see "easy way" documentation)
That is what I did but from Ubuntu 14.04 to Centos 7. After you run the database upgrade make sure you do the permissions for MySQL. See the WIKI for instructions.
bb
Markymark
Post by Markymark »
Thanks so far!
Regarding step 3 (import database):
I dumped the database (mysqldump -u root -p zm > zm.sql) on the old system and installed LAMP and ZM on the new system. According to the documentation the next step would be to create the database and 'zmuser':
sudo mysql -uroot -p < /usr/share/zoneminder/db/zm_create.sql
mysql -uroot -p -e "grant select,insert,update,delete,create,alter,index,lock tables on zm.* to 'zmuser'@localhost identified by 'zmpass';"
My approach would be to skip both steps and import the old database instead:
mysql -uroot -p zm < /path/to/zm.sql
Will this do the trick?
Rgrds,
Mark
Looks right if you are sure of your commands. I have to admit that I used Webmin to import the zm dump of the old installation. I created an empty database called zm then ran the sql dump file, went to a command prompt and ran the zm upgrade and then the permissions string. Make sure you have added innodb_file_per_table to my.cnf then restart MySQL before you add your zm database.
Markymark
Post by Markymark »
@bbunge & knnniggett,
many thanks for your recommendations. ZM runs like a charm again. Regarding the database migration I used the following steps:
Dump database on old system: mysqldump -u root -p zm > zm.sql
Create db on new system: mysql -uroot -p -e "CREATE DATABASE zm;"
(Create 'zmuser' according to wiki & docs.)
Import db from old system: mysql -uroot -p zm < /mnt/zm.sql
Update db: zmupdate.pl (without any options)
Pretty easy! :D
Rgrds,
Mark
But... did you do:
Markymark
Post by Markymark »
Yes, I did this right after I imported the db. I skiped this step in the list above because it is not specific with respect to the migration of the db. But it is a good idea to make this clear.
Greetings
Mark
