It does not show streaming video
zusul
Post by zusul »
Hi
Ubuntu 14.04х64
It does not show streaming video, photo saved
socket_sendto( /var/run/zm/zms-830140s.sock ) failed: No such file or directory
getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-147782s.sock ) failed: No such file or directory - checkStreamForErrors()
Re: It does not show streaming video
Did you enable CGI?
Did you edit the PATH_ZMS
zusul
Post by zusul »
bbunge wrote:Did you enable CGI?
Module cgi already enabled
PATH_ZMS /zm/cgi-bin/nph-zms
asanti
Post by asanti »
Try This info: worked for me
viewtopic.php?f=34&t=24265
edit /etc/apache2/conf-available/zoneminder.conf
#ScriptAlias /zm/cgi-bin "/usr/lib/zoneminder/cgi-bin"
ScriptAlias /zoneminder/cgi-bin "/usr/lib/zoneminder/cgi-bin"
service apache2 restart
service zoneminder restart
danz
Re: It does not show streaming video [SOLVED]
Post by danz »
I had difficulty with this too. Not sure if my solution exactly matches your problem, but this worked for me. I am using version 1.32.3 on Ubuntu 1804.1 LTS. I found that, that within the ZoneMinder console, if I set Options>System>Auth_Relay to "None," or unchecked OPT_USE_AUTH, I could see streaming video. The problem turned out to be a mismatch of time zones, causing the authentication to throw an error. When installing ZoneMinder, I configured the time zone per the instructions. This however did not match the computer time. I simply executed the following line from terminal to set the computer time to the same time zone as configured in ZoneMinder, and the problem immediately resolved. Additionally this made the time stamps the correct local time.
cp /usr/share/zoneinfo/America/Chicago /etc/localtime
[Substitute your timezone for Chicago. Note the space before /etc.]
Restart ZoneMinder.
