cant add monitors or make changes
iitywygms
Post by iitywygms »
Hi All:
Had a system crash. New install.
14.04 ubuntu using iconner ppa.
I followed this guide exactly,
Everything appears to install okay. I can log in as admin.
If I go to add a user I cannot click on add new user. it does not "click"
I cannot add a new monitor. It also does not "click"
The log file is blank. If I go to /var/logs/zm nothing is there.
I cannot click on refresh, filters, or most other things.
I can click on options and everything shows up, but as I said above, I cant add a user.
I would post more log files but I cant find any??
I have purged and reinstalled twice now but nothing helps.
Can anyone help?
Thanks.
iitywygms
Re: cant add monitors or make changes
Post by iitywygms »
Followed the guide here and now it is working.
https://wiki.zoneminder.com/Common_Issu ... _on_Ubuntu
Ubuntu 14.04 - ZM 1.26.5 or later to 1.28.109 or the latest PPA version
That 1.28.0 install is obsolete. Guess you did not read the note at the top of the page,,,
See:
