Generate video from Multiple Events
DVB Hardware
Post by DVB Hardware »
Is it possible to select multiple events and generate a video?
I can do it for a single event
Can't seem to find any info after 3 hrs of searching.
Re: Generate video from Multiple Events
Event Export instead of Video export. I think will allow you to do just video files of multiple events by selection.
You can create video for each event and export the event video files as one zip or tar but you will have to combine the clips after download. Several tools will do this including Windows Movie Maker.
DVB Hardware
Thank, that's what I figured....was just looking for a way in ZM without optional steps.
