Whats wrong with my filter?
Biggus
Post by Biggus »
I've built a new ZM Ubuntu server.
However I've set up a background filter to delete events older then 7 days however it doesn't work. Use to work fine on my old installation. If I run the filter manually it works OK, just it doesn't work in background mode. Am I doing something wrong?
Re: Whats wrong with my filter?
less than or equal to
-7 day or -1 week
I'm sure there will be a debate about day or days. But the -1 week should work
My filter worked better like this:
Time greater than
7 Day
My filter which is exactly like the one posted originally did not work for me on all my zoneminder installs. So tried the above and it worked like a charm.
Seems the s suffix doesn't matter so Days or Day should work the same.
