Image not rendering
Jzjr
Image not rendering
Post by Jzjr »
I have installed two Wanscam cameras at home, both of which are the same model.
One of these works fine, the other doesn't. I have set them both up in the same way.
I see:
PC Load is never above 0.6 on a dual core machine, not sure what could be causing it. The image does show up when I log directly in to the camera to view.
mikb
Re: Image not rendering
Post by mikb »
Looks like somewhere the resolution is set up wrongly, you seem to have the image repeated "across" *about* 4 (or 8) times, and it's a quarter of the right height.
It's as if you've got a 320x240 picture being delivered into a 640x480 space, but not quite such round numbers. A bit over 320 wide into a bit under 640, or some such.
Check the camera's resolution and ZM's resolution settings.
