Ffmpeg okay Remote does not work
iitywygms
Post by iitywygms »
Trying to get the remote source to work on my Dahua IPC-HFW4300S V2
Zm version 1.28.1
Ubuntu 12.04
Ffmpeg works with the following.
General
Source type Ffmpeg
Source
source path rtsp://username:password@192.168.2.1/live
Remote Method rtp/rtsp
Remote does not work the following.
General
Source type remote
Source
remote protocol rtsp
remote method rtp/rtsp
remote host name 192.168.2.1
remote host port 554
remote host path rtsp://username:password@192.168.2.1/live
Anyone have a idea of why remote always fails?
log shows no rtsp sources.
Re: Ffmpeg okay Remote does not work
Remote Host Path /live?user=username&pwd=password
everything else looks OK
iitywygms
Post by iitywygms »
I entered in Remote Host path exactly like this
Of course I changed username and password to the actual.
Still get no rtsp source.
Well, check documentation for your camera to learn how to pass user and password. My example works with some cameras. Some cameras do not need authentication to stream video in remote.
My friend Google let me to this page: http://www.usefulramblings.org/?page_id=4974
This was suggested: /cgi-bin/snapshot.cgi?loginuse=[USERNAME]&loginpas=[PASSWORD]
But.. if you change the video stream make sure you match the resolution of that stream!
There are three different source types that are all theoretically interchangeable with an IP camera:
ffmpeg
libvlc
remote
In practice, no single source type works well in all cases, which is why you have three to choose from. Pick the one that works the best for your camera.
With regards to the Remote source type, you've only provided half of what we need to troubleshoot this kind of camera issue.
You've shown us your input, which is quite helpful, but on the output side you stated "doesn't work", which is not helpful. What we need is your log. In this case, you need to turn up your Debug to level 5 and show the entire RTSP handshake for this camera, which begins with OPTIONS and ends with TEARDOWN (or some kind of failed error message). Paste the whole thing from start to finish. Don't cherry pick the error message. See the RTSP wiki for all the names of the RTSP protocol directives, which will show up in your log: https://en.wikipedia.org/wiki/Real_Time ... g_Protocol
No guarantees. Despite well laid out rtsp rfc's, it seems each manufacturer comes up with its own, unique twist to the standard, which can cause the Remote source type to not establish a stream. Getting this up to speed will take a software programmer with experience in this kind of programming, which none of us are.
iitywygms
Post by iitywygms »
bbunge wrote:My friend Google let me to this page: http://www.usefulramblings.org/?page_id=4974
Appreciate the link. I read through that page before. They use Ffmpeg. And I can get Ffmpeg to work without issue.
I am not having a problem getting the cameras to work. Just experimenting with using remote as the source.
I really do appreciate the effort and response. Thank you.
knnniggett wrote: With regards to the Remote source type, you've only provided half of what we need to troubleshoot this kind of camera issue.
I will turn on debugging and report more info when I can. Right now, I am just messing around trying to get the lowest cpu load on my server.
I really wish I could offer some help with programming and such.
Your effort, along with the others here is greatly appreciated.
My suggestions for ffmpeg are to:
Use the lowest resolution you can live with (320X240 or whatever your camera can deliver)
Lower the frame rate (5 FPS) and the key frame interval
Use TCP (append source line with ?tcp)
Get it working and push it higher to see what your system can take.
