Getting Zoneminder to start automatically
swulf
Post by swulf »
I running Zoneminder V1.28.1 under Ubuntu Server 14.04.3 LTS. I've configured my PC to boot automatically after a power failure, and Zoneminder also starts once the system boots. However, it comes up in the 'Stopped' state which is not good. I want it to automatically enter the 'Running' state so that it will not just sit there, but will actually monitor things.
Can anyone point me to a way to do that?
Thanks.
asker
Re: Getting Zoneminder to start automatically
Post by asker »
swulf wrote:Hi,
Thanks.
Did you install using the PPA? If so
Did you add "sleep 10" just after start() in /etc/init.d/zoneminder? I use the same setup and mine starts in running state on reboot.
Please read before posting:
ES docs
zmNinja docs
swulf
Post by swulf »
Hi asker,
Yes, I did install from the PPA. I made this change per your advice and it works.
Thanks!
start() {
        echo -n "Starting $prog: "
        mkdir -p $RUNDIR && chown www-data:www-data $RUNDIR
to
start() {
        sleep 10
When all else fails read the instructions...
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
swulf
Post by swulf »
I was unaware of this page, thank you for pointing it out.
I prefer to use monit to keep things running
ocne you get monit installed, you can use the following as a config for zm.
check process zmdc.pl with pidfile /run/zm/zm.pid
group zm
start program = "/etc/init.d/zoneminder start"
stop program = "/etc/init.d/zoneminder stop"
petec
Post by petec »
hello, I know this is old post.
I have the same problem on FrreBSD, with ZM running in jail....
anybody know how to move it automatically to running state after power failure?
