Exportet Videos struggling
DasBrot
Post by DasBrot »
Hello
i have one Test Camera with 2Mp 1920 x 1080
on a I5 4570 with 8 GB Ram on Ubuntu Linux
The Life view is ok but not 25 Frames ... maybe 12 ? Frames. When i Export a Video there is a lot of struggling in the Video.
is this normal ? What is with 12 Cameras ? is the Hardware to Slow ?
System load is ~ 0,8 - 1,28 in not viewing mode, only Motion detektion in the back with one camera.
Bernd
Re: Exportet Videos struggling
By struggling I would guess you mean the motion is jumpy?
Which version of Ubuntu?
I suggest you lower your resolution and frame rate bit to see of it helps.
Turn off CREATE_ANALYSIS_IMAGES. Change PATH_MAP and PATH_SWAP to use ramdisk (/dev/shm or /run/shm for Ubuntu 14.04. /dev/shm for Ubuntu 15.04). This will take a bit of load off of your hard drive.
Ubuntu will, by default, use half of available RAM for a ramdisk. I have reduced this down to 1 GIG for my i5 system with 8 GIG RAM running 16 cameras with no problems.
bb
DasBrot
Post by DasBrot »
Hi
ok i mean jumpy sorry for my english.
Here is a Video:
http://ixk2q6wzbvboblkj.myfritz.net/own ... XkbqZcEqyR
i have reduced the resolution but alway the same. in life view the framerate is 12 but the Window says its 25 .. With and without recording.
I try the ramdisk when i am at home.
Bernd
DasBrot
Re: Exportet Videos Jumpy
Post by DasBrot »
I have made your Settings but the jumpy videos are still there.
The only error in log is when i look the life stream ist :
Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor Monitor-11
is the Harddrive to slow for one full hd camera ?
Bernd
