1920x1080 squished into a 4:3 square, not widescreen issue
chrisn0123
Post by chrisn0123 » Tue Feb 03, 2015 8:36 am
Hi all,
Weird issue!
Our cameras are 1280x1080 (Dlink DCS-2230) and have a problem, where the video is squished. Looks like it forces it into a square 4:3, rather than 16:9.
If I set the camera to 1280x720, it works ok and looks 16:9. The input is RTSP if that is relevant. (Back end = CentOS 6.x)
If I view image properties in the browser, it does show it as 1280x1080 resolution.. so it is definitely 1280x1080. Just ZM is showing it like it is 4:3.
Please see screenshot:
https://www.amazon.co.uk/clouddrive/sha ... jSPOzBaYKY
Any ideas?
Cheers
Re: 1280x1080 squished into a 4:3 square, not widescreen iss
Post by knight-of-ni » Wed Feb 04, 2015 1:10 am
Monitor Config -> Source -> (enable) Preserve Aspect Ratio
And set Options -> Config -> DEFAULT_ASPECT_RATIO to 16:9
If you don't mind scroll bars when the image resolution is larger than than the window, you can turn off Preserve Aspet Ratio altogether.
chrisn0123
Re: 1920x1080 squished into a 4:3 square, not widescreen iss
Post by chrisn0123 » Wed Feb 04, 2015 8:19 am
Ahh thanks for help!! It was the config option I had missed. Didn't know that one was there :)
