Zoneminder 1.28 the Easy Way Question
prenger745
Post by prenger745 »
I am following the write up "Ubuntu Server 14.04 64-bit with Zoneminder 1.28.0 the easy way"
I am doing the cambozola part and did this command:
tar -xzvf cambozola-latest.tar.gz
That worked fine.
The next command I copied and pasted is:
replace 935 with cambozola version downloaded
And it comes back with:
replace: No to-string for last from-string
Not sure if that is correct or not?
Any thoughts?
Dan
Re: Zoneminder 1.28 the Easy Way Question
That is an instruction to check the version of cambozola. Not a command input. Somehow that line got tagged as an input. Will fix it.
Now reads: replace 935 in the next line with cambozola version downloaded
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
Sorry for the confusion...
prenger745
Thank you for the clarification!
Danno
