Selective recording
SBonnet
Selective recording
Post by SBonnet »
After much struggle I finally got ZM working. The only problem is when set in the mocap setting it seems to record everything rather than just the events with a "score." Are there settings I can change to make this better? I don't have a huge hard drive. Also the possibility exists that the camera might be picking up on ambient movement. Leaves blowing around and such, though this does not have a score. Any thoughts?
mikb
Re: Selective recording
Post by mikb »
SBonnet wrote:Hello,
Just clarify what you mean by "mocap" setting ...
MoDECT - Only records events where there was motion (a worthy score)
MoCORD - Records all the dull bits between AS WELL, but snaps them off into separate pieces (some will have low or 0 score)
Which did you pick? And which did you want really? :)
