Install Question
Medeoker
Install Question
Post by Medeoker »
Hey there,
I'm starting a from scratch install and am following the following Wiki instruction:
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
Silly question; do I need to install mysql server first before following the steps in this wiki article? I've run through the install by following the instructions but I'm getting a cannot connect to the mysql server. If I need to install mysql, what db account do I need to setup in order for ZoneMinder to access the db? Thanks
**Edit**
Nevermind. Got it. Need to have Mysql installed first. Everything worked like a charm. Thanks!
Re: Install Question
Right at the top of the How to is:
Install Ubuntu
I strongly recommend you used the mini.iso installer as I've had some issues with 12.04-5 server CD, Install Basic Server, OpenSSH Server, and LAMP Server
LAMP will install Apache, MySQL and PHP.
If you are just learning this I recommend you yse teh latest version of Ubuntu with these instructions:
Messing around with the release in the PPA repository is for the more experienced. Yes, there are some nifty features in 1.27 and it is your call....
bb
