Purge When Full not Working
krownos
Post by krownos »
Purge When Full not working. I have it set to 95% and the disk fills to 100%. I see events being purged in the log files but it never deletes the files on the hard drive.
mikb
Re: Purge When Full not Working
Post by mikb »
krownos wrote:Purge When Full not working. I have it set to 95% and the disk fills to 100%. I see events being purged in the log files but it never deletes the files on the hard drive.
Is ZMAUDIT working and running, I think that the "Purge When Full" only removes the database entry, it's up to ZMAUDIT to notice that there are redundant files on the disk.
[Options/System/RUN_AUDIT - ticked?]
Also, what options have you got for "delay deleting until later" under config, there's an option that defers the actual deleting for later.
[Options/System/OPT_FAST_DELETE - unticked?] - delete only event db records for speed
Otherwise, not sure!
krownos
Post by krownos »
This did not correct my problem. I am getting no errors in any log system or zoneminder.
krownos
Post by krownos »
Is there any way to run that process by the command line.
bb99
Post by bb99 »
I'm guessing that the "run in background" box didn't get ticked when you saved the filter. Check it out. Otherwise repair the database per wiki instructions
