Add a New Monitor - Problem
tonydotigr
Post by tonydotigr »
Greetings!
I am having problems with 'Add New Monitor' on verision of ZoneMinder, v1.26.5 using Ubuntu 14.04.1 LTS (Trusty). When I click on it nothing happens. Am to access the options area though.
Tried the following commands and still have the problem.
sudo apt-get install python-software-properties
sudo add-apt-repository ppa:iconnor/zoneminder-master
sudo apt-get update
Any ideas?
PacoLM
Re: Add a New Monitor - Problem
Post by PacoLM »
Do you have cambozola installed?
Did you follow the setup here:
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
Did you enable cgi in Apache2?
tonydotigr
<SOLVED> Add a New Monitor - Problem
Thanks all for the insight. Was able to solve my problem reading this other thread.
http://www.zoneminder.com/forums/viewto ... 30&t=22520
