Libvlc doesn't work
Biggus
Libvlc doesn't work
Post by Biggus »
I'm running a Ubuntu 14.04 server with ZM 1.27.1 installed. I installed this from the iconnor/zoneminder-master PPA.
When using FFMPEG my camera works, however when attempting to use libvlc it doesn't. I've installed libvlc.
Is this a known bug or am I doing something wrong?
PacoLM
Re: Libvlc doesn't work
Post by PacoLM »
Could you tell me how to install the lastest version under Ubuntu 14.04?
Regards,
PacoLM
Biggus
Post by Biggus »
- apt-add-repository ppa:iconnor/zoneminder-master
- apt-get update
- apt-get install zoneminder
- cp /etc/zm/apache.conf /etc/apache2/sites-enabled/zm.conf
- a2enmod cgi
Everything works apart from Libvlc.. Just wondering if I'm the only one.
You are not the Lone Ranger. I've tried several times with basically your install with the same results. FFMPEG works fine, however, even though FFMPEG is not installed with 14.04!
bb
PacoLM
Post by PacoLM »
Biggus wrote:- apt-add-repository ppa:iconnor/zoneminder-master
- apt-get update
- a2enmod cgi
Thanks, I will give it a try!
Biggus
Post by Biggus »
Hi PacoLM,
Did you manage to test? I'm keen to get LIBVLC working :-)
PacoLM
Post by PacoLM »
Well, Ubuntu server 14.04 and ZM1.27.99 working, but didn't tried libVLC, only ffmpeg. Will try it these days, keep you informed!
Biggus
Post by Biggus »
OK, I've just updated to 1.27.99 with iconnor/zoneminder-master PPA.
FFMPEG works fine.
Libvlc doesn't
PacoLM
Post by PacoLM »
Have you installed libvlc?
Just in case you don't, try this:
apt-get install libvlc-dev libvlc5 libvlccore-dev libvlccore5 vlc-data vlc
PacoLM
PacoLM
Post by PacoLM »
Just tried it after installing the vlc libraries, it works way better than with ffmpeg
Re: Libvlc doesn't work without additional VLC files.
Wow! Got it to work!!! Below are the steps I used (basically from my "Easy" series).
I should add that I'm watching an H.264 camera 30 miles away, ported through a firewall, with little strain on my DSL!
Install Ubuntu Server
Install Basic Server (if you used the mini.iso), OpenSSH Server, and LAMP Server (LAMP installs Apache2, PHP, and MySQL server)
Log in then become root:
sudo su
apt-get update
apt-get upgrade
apt-get dist-upgrade
Optional: Set static IP address
nano /etc/network/interfaces
Make changes similar to this:
auto eth0
iface eth0 inet static
address 192.168.1.10
netmask 255.255.255.0
gateway 192.168.1.1
dns-nameservers 192.168.1.1
Note: for Ubuntu 14.04 the resolv.conf is dynamically assigned. The "dns-servers" entry in the interfaces file will set the DNS Multiple DNS server entries can be used.
Reboot server
Add Repository
apt-get install python-software-properties
add-apt-repository ppa:iconnor/zoneminder-master
apt-get update
Install Zoneminder
Note: a couple of package configurations will open up. These are to configure Nullmailer. You can just OK them and come back to configure them later.
Install "extra" VLC components (vlc may be optional?)
apt-get install libvlc-dev libvlccore-dev vlc
Add delay to allow MySQL to start before Zoneminder
nano /etc/init.d/zoneminder
Add sleep 15 as shown:
start() {
sleep 15
echo -n "Starting $prog: "
Ctrl+o Enter to save
CTRL+x to exit
Create a directory in apache2
mkdir /etc/apache2/conf.d
Create two symbolic links
ln -s /etc/zm/apache.conf /etc/apache2/conf.d/zoneminder.conf
ln -s /etc/zm/apache.conf /etc/apache2/conf-enabled/zoneminder.conf
CGI is not enabled in Ubuntu 14.04 by default. Enable it this way:
a2enmod cgi
Create a new user
adduser www-data video
Restart Apache
/etc/init.d/apache2 force-reload
or
service apache2 restart
Install Cambozola (needed if you use Internet Explorer)
cd /usr/src && wget http://www.andywilcock.com/code/cambozo ... est.tar.gz
tar -xzvf cambozola-latest.tar.gz
replace 935 with cambozola version downloaded
cp cambozola-0.935/dist/cambozola.jar /usr/share/zoneminder
You should now be able to access the web server using https://servername
NTP Daily Sync
nano /etc/cron.daily/ntpdate
Copy the following into nano
!/bin/sh ntpdate ntp.ubuntu.com
CTRL+x to exit
chmod 755 /etc/cron.daily/ntpdate
Open Zoneminder in web browser
http://serverip/zm
Click Options
Uncheck: Check with zoneminder.com for updated versions (?) click Save
Click Images tab
check Is the (optional) cambozola java streaming client installed (?) Click Save
PacoLM
Post by PacoLM »
Congratulations!
Biggus
Post by Biggus »
Cheers bbunge
Rebuilt everything from scratch and followed your instructions and now this works perfect.
Ubuntu 14.
ZM 1.27.99
Libvlc
Ffmpeg
Only issue I have now is with cambozola not working in IE correctly but I'll put in another post about that.
carcachute
Post by carcachute »
I encountered this problem too. The Zoneminder package seems to install libvlc but not vlc. When I looked in /var/log/syslog, you'll see messages about missing VLC plugins.
I'm guessing the vlc package contains the plugins necessary for libvlc to work with ZM.
Unfortunately the vlc package also installs X11, QT, etc., which is a bunch of crud that is completely unnecessary for a headless server box.
carcachute wrote:I encountered this problem too. The Zoneminder package seems to install libvlc but not vlc. When I looked in /var/log/syslog, you'll see messages about missing VLC plugins.
The vlc-core package contains the necessary support for zoneminder w/o requiring any Xorg packages.
I think on Ubuntu the name of the package is libvlccore... the exact name varies by distro.
