No video with Zoneminder v1.27.1
orsty3001
Post by orsty3001 »
I'm running Slackware 14.1 and Apache/2.4.9
These errors pop up for each camera in the log when I try to view the cameras.
Wrong JPEG library version: library is 80, caller expects 62
socket_sendto( /tmp/zm/zms-xxxxxxs.sock ) failed: Connection refused
FAT [SQL-ERR dbFetchAll no result, statement was 'select distinct Component from Logs where not isnull(Component) and Level <= ? order by Component asc']
zmc -d exited abnormally, exit status 255
DALDON
Re: No video with Zoneminder v1.27.1
Post by DALDON »
Did you true:
a2enmod cgi ?
orsty3001
Post by orsty3001 »
Yes, it's enabled.
That first error about the jpeg library version mismatch is what I suspect to be wrong.
I assume that you are building from source since you are on slackware...
What version are your jpeg libraries? You really want jpeg-turbo, or something newer
orsty3001
Post by orsty3001 »
libjpeg-turbo is installed and is version 1.3.0.
DALDON
Post by DALDON »
orsty3001 wrote:I'm running Slackware 14.1 and Apache/2.4.9
I have the same problem now. I have this after login users via apache, but if I disable this - it works fine again...
It's very strange...
