Just updated from v1.25 to v1.27 and have lost control ability for Foscam FI8910W camera. Tried to see if I could adjust the code slightly but am having no luck in restoring the ability to control the camera. Tried to use the existing custom .pm file, but got errors, then decided to model off of the FI8908W.pm file (that apparently comes with this version of ZM) and no longer get errors but camera still does not move...streaming and recording is just fine.
Attached is the pm code I am trying to use for the FI8910W camera.
Any help is appreciated...
Foscam FI8910W control issue with 1.27
Re: Foscam FI8910W control issue with 1.27
# ZoneMinder Foscam FI8910W IP Control Protocol Module
# primary control script from Troy Will Copyright (C) 2012
# from the Zoneminder PanasonicIP.pm by Philip Coombes, Copyright (C) 2001-2008
# This module contains an implementation of a Foscam IP FI8910W camera control
# protocol
package ZoneMinder::Control::FoscamFI8910W;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Foscam FI8910W IP Control Protocol
use Time::HiRes qw( usleep );
sub new {
my $class = shift;
my $id = shift;
my $self = ZoneMinder::Control->new($id);
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD {
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open {
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
$self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION );
$self->{state} = 'open';
sub close {
my $self = shift;
$self->{state} = 'closed';
sub printMsg {
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd {
my $self = shift;
my $cmd = shift;
my $result = undef;
my ($user, $password) = split /:/, $self->{Monitor}->{ControlDevice};
if ( !defined $password ) {
# If value of "Control device" does not consist of two parts, then only password is given and we fallback to default user:
$password = $user;
$user = 'admin';
$cmd .= "user=$user&pwd=$password";
printMsg( $cmd, "Tx" );
### X This forum does not like h t t p here
my $req = HTTP::Request->new( GET=>"X://".$self->{Monitor}->{ControlAddress}."/$cmd" );
if ( $res->is_success )
$result = !undef;
else
Error( "Error check failed: '".$res->status_line()."' for URL ".$req->uri() );
return( $result );
sub reset
my $self = shift;
Debug( "Camera Reset" );
$self->sendCmd( 'reboot.cgi?' );
sub moveConUp {
my $self = shift;
Debug("Move Up");
#my $cmd = "decoder_control.cgi?command=0"; # original up
my $cmd = "decoder_control.cgi?command=2"; # for inverted camera operation
$self->sendCmd($cmd);
sub moveStop {
my $self = shift;
Debug("Move Stop");
my $cmd = "decoder_control.cgi?command=1";
sub moveConDown {
my $self = shift;
Debug("Move Down");
#my $cmd = "decoder_control.cgi?command=2"; # original down
my $cmd = "decoder_control.cgi?command=0"; # for inverted camera operation
sub moveConLeft {
my $self = shift;
Debug("Move Left");
#my $cmd = "decoder_control.cgi?command=6"; # original left
my $cmd = "decoder_control.cgi?command=4"; # for inverted camera operation
sub moveConRight {
my $self = shift;
Debug("Move Right");
#my $cmd = "decoder_control.cgi?command=4"; # original right
my $cmd = "decoder_control.cgi?command=6"; # for inverted camera operation
sub moveConUpRight {
my $self = shift;
Debug("Move Diagonally Up Right");
#my $cmd = "decoder_control.cgi?command=90"; # original diagonal up right
my $cmd = "decoder_control.cgi?command=93"; # for inverted camera operation
sub moveConDownRight {
my $self = shift;
Debug("Move Diagonally Down Right");
#my $cmd = "decoder_control.cgi?command=92"; # original diagonal down right
my $cmd = "decoder_control.cgi?command=91"; # for inverted camera operation
sub moveConUpLeft {
my $self = shift;
Debug("Move Diagonally Up Left");
#my $cmd = "decoder_control.cgi?command=91"; # original diagonal up left
my $cmd = "decoder_control.cgi?command=92"; # for inverted camera operation
sub moveConDownLeft {
my $self = shift;
Debug("Move Diagonally Down Left");
#my $cmd = "decoder_control.cgi?command=93"; # original diagonal down left
my $cmd = "decoder_control.cgi?command=90"; # for inverted camera operation
#Stop
sub moveStop
my $self = shift;
Debug( "Move Stop" );
$self->sendCmd( 'decoder_control.cgi?command=1&' );
#Move Camera to Home Position
sub presetHome
my $self = shift;
Debug( "Home Preset" );
$self->sendCmd( 'decoder_control.cgi?command=25&' );
#Turn IR on
sub wake {
my $self = shift;
Debug("Wake - IR on");
my $cmd = "decoder_control.cgi?command=95&";
#Turn IR off
sub sleep {
my $self = shift;
Debug("Sleep - IR off");
my $cmd = "decoder_control.cgi?command=94&";
1;
# protocol
use 5.006;
use strict;
use warnings;
sub new {
my $class = shift;
my $id = shift;
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD {
my $self = shift;
$name =~ s/.*://;
sub open {
my $self = shift;
use LWP::UserAgent;
sub close {
my $self = shift;
sub printMsg {
my $self = shift;
my $msg = shift;
sub sendCmd {
my $self = shift;
my $cmd = shift;
my $result = undef;
$password = $user;
$user = 'admin';
$result = !undef;
else
return( $result );
sub reset
my $self = shift;
sub moveConUp {
my $self = shift;
Debug("Move Up");
sub moveStop {
my $self = shift;
Debug("Move Stop");
sub moveConDown {
my $self = shift;
Debug("Move Down");
sub moveConLeft {
my $self = shift;
Debug("Move Left");
sub moveConRight {
my $self = shift;
my $self = shift;
my $self = shift;
sub moveConUpLeft {
my $self = shift;
my $self = shift;
#Stop
sub moveStop
my $self = shift;
sub presetHome
my $self = shift;
#Turn IR on
sub wake {
my $self = shift;
#Turn IR off
sub sleep {
my $self = shift;
1;
I had the same problem with my Foscam FI8910W after upgrading from 1.25
First off I moved the file FoscamFI8910W.pm file from /usr/share/perl5/ZoneMinder/Control to /usr/share/perl/5.14.2/ZoneMinder/Control
then edit the file as follows:
#$self->{ua}->agent( "ZoneMinder Control Agent/" . ZM_VERSION );
to
$self->{ua}->agent( "ZoneMinder Control Agent" );
Sorted my issue and I can now control my camera.
to
Thanks yawnorama, that did the trick.
I noticed that didn't have the preset controls included in that control script... here's a bastardised version for anyone keen for the 8 preset controls.
# protocol
use 5.006;
use strict;
use warnings;
# Foscam FI8908W IP Control Protocol
sub new
my $class = shift;
my $id = shift;
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
$name =~ s/.*://;
sub open
my $self = shift;
use LWP::UserAgent;
sub close
my $self = shift;
sub printMsg
my $self = shift;
my $msg = shift;
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
$password = $user;
$user = 'admin';
$result = !undef;
else
return( $result );
sub reset
my $self = shift;
sub moveConUp {
my $self = shift;
Debug("Move Up");
my $cmd = "decoder_control.cgi?command=2&"; # for inverted camera operation
sub moveStop {
my $self = shift;
Debug("Move Stop");
my $cmd = "decoder_control.cgi?command=1&";
sub moveConDown {
my $self = shift;
Debug("Move Down");
my $cmd = "decoder_control.cgi?command=0&"; # for inverted camera operation
sub moveConLeft {
my $self = shift;
Debug("Move Left");
my $cmd = "decoder_control.cgi?command=4&"; # for inverted camera operation
sub moveConRight {
my $self = shift;
my $cmd = "decoder_control.cgi?command=6&"; # for inverted camera operation
my $self = shift;
my $cmd = "decoder_control.cgi?command=93&"; # for inverted camera operation
my $self = shift;
my $cmd = "decoder_control.cgi?command=91&"; # for inverted camera operation
sub moveConUpLeft {
my $self = shift;
my $cmd = "decoder_control.cgi?command=92&"; # for inverted camera operation
my $self = shift;
my $cmd = "decoder_control.cgi?command=90&"; # for inverted camera operation
#Stop
sub moveStop
my $self = shift;
sub presetClear {
my $self = shift;
my $params = shift;
Debug("Clear Preset $preset");
my $cmd = "nphPresetNameCheck?Data=$preset&";
sub presetSet {
my $self = shift;
my $params = shift;
my $presetCmd = 30 + ( $preset * 2 );
Debug("Set Preset $preset: $presetCmd");
my $cmd = "decoder_control.cgi?command=$presetCmd&";
sub presetGoto {
my $self = shift;
my $params = shift;
my $presetCmd = 31 + ( $preset * 2 );
Debug("Goto Preset $preset: $presetCmd");
sub presetHome {
my $self = shift;
Debug("Home Preset");
my $cmd = "decoder_control.cgi?command=25&";
#Turn IR on
sub wake {
my $self = shift;
#Turn IR off
sub sleep {
my $self = shift;
1;
