I have a security light that turns on and off frequently in my yard. Zoneminder detects both the turning on and the turning off of that light as a motion detect. Would be great to be able to calibrate ZM so that such events, in and of themselves, are not enough to trigger an alarm. Turning "on" plus further movement would be great.. turning "off" shouldn't trigger at all..
It isn't a huge problem, but it does cause a LOT of captures that don't need to be captured.
Security Light detection
Re: Security Light detection
Hello stuntman,
Your feature request is already provided within ZoneMinder!!
see: http://www.zoneminder.com/forums/viewto ... 29&t=19582
Kind regards, Christo
Have you selected a zone to do not include the area where the lights are on?
mini-ITX system (4 IPCams - Ubuntu20.04 - ZM1.34.15)
TelegramBot
Hello PacoLM,
Youll have to select te zone(s) that are effected by these ligths!!
Make sure to look into the statics on events caused by these ligths to adjust your settings.
(duration / frames etc)
Good luck, Christo
Good luck, Christo
Hi Christo,Christo wrote:Hello PacoLM,
Good luck, Christo
I was trying to give an answer to the original poster, not asking another question...
Regards,
PacoLM
TelegramBot
Hello PacoLM,
I know but ZoneMinder is capable to handle these events when this occurs within active zones.
So, your answer suggested a solution that might not always be suitable!!
Kind regard, Christo
Again, having defined a exclusive zone for the area that covers the light should fix the problem, as the event is NOT going to be triggered when the image changes in the light alarm area...
If I understood it correctly, the user wants to avoid events triggered by the lights, isn't it?
TelegramBot
