No streaming with sock errors
zonehome
Post by zonehome »
ZM 1.26.4 on Debian Wheezy. I installed using instructions here:
http://www.zoneminder.com/forums/viewto ... 30&t=21304
I have two network cameras that worked with a previous 1.25.0 installation, but when I try to watch either the live stream or playback an event, I get no video. Errors related to the temp sock files appear in the log as shown in the attached picture.
I've tried a number of things to fix this, such as reinstalling libjpeg-turbo and changing the sock temp directory location, with no luck.
Thanks for any suggestions you may have.
jonatha
Re: No streaming with sock errors
Post by jonatha »
I have a similar problem, but it only happens when the monitor settings ask for 24-bit colour. 8-bit grayscale works fine.
(24-bit colour used to work fine too [prior to the latest update]....; 32-bit colour gives lack of memory messages.)
zonehome
Post by zonehome »
I figured it out, with the help of this post:
http://tom.webarts.ca/Blog/new-blog-ite ... ndto-error
The streaming immediately started working once I changed the Apache2 conf file to match what Tom posted in his blog. There were several differences in the one I had been using, which came from the ZoneMinder source install bundle (Virtual Server lines, trailing slash on the ScriptAlias, and php open tag not set).
jonatha
Post by jonatha »
In my case, all I had to do was drop the database and reinitialize it.
