Mini Bug
nokia001
Mini Bug
Post by nokia001 » Mon Sep 09, 2013 9:36 am
I'm using Gentoo. Today a have installed 1.26.2.
Now there is a error:
Sep  9 11:34:59 localhost zmpkg[461]: INF [Command: start]
Sep  9 11:34:59 localhost sudo:     root : TTY=pts/0 ; PWD=/var/www/localhost/htdocs/zm ; USER=apache ; COMMAND=/bin/true
Sep  9 11:34:59 localhost sudo: pam_unix(sudo:session): session opened for user apache by root(uid=0)
Sep  9 11:34:59 localhost sudo: pam_unix(sudo:session): session closed for user apache
Sep  9 11:34:59 localhost sudo:     root : TTY=pts/0 ; PWD=/var/www/localhost/htdocs/zm ; USER=apache ; COMMAND=/usr/local/bin/zmupdate.pl -f
Sep  9 11:35:15 localhost sudo: pam_unix(sudo:session): session closed for user apache
Sep  9 11:35:15 localhost sudo:     root : TTY=pts/0 ; PWD=/var/www/localhost/htdocs/zm ; USER=apache ; COMMAND=/usr/local/bin/zmdc.pl check
Sep  9 11:35:15 localhost sudo: pam_unix(sudo:session): session opened for user apache by root(uid=0)
Sep  9 11:35:15 localhost sudo:     root : TTY=pts/0 ; PWD=/var/www/localhost/htdocs/zm ; USER=apache ; COMMAND=/usr/local/bin/zmfix
Sep  9 11:35:15 localhost undef[697]: ERR [Config mismatch, expected 221 items, read 216. Try running 'zmupdate.pl -f' to reload config.]
Sep  9 11:35:15 localhost zmpkg[461]: ERR [Unable to run "sudo -u apache /usr/local/bin/zmfix", output is ""]
please help.
thx
nokia001
Re: Mini Bug
Post by nokia001 » Mon Sep 09, 2013 12:33 pm
Problem solved.
I downloaded the zmupdate and the sql_create_file from git.
thx
