IP6C11-P3 configuration?
GalenCox
Post by GalenCox »
I got a camera for a friend but unfortunatly without any documentation.
Only the type infromation on the case (IP6C11-P3).
I found out that the comunication port is '8200' by default. But I did not get any stream or picture.
Does anyone have any experiance with this camera? How to configurate ZM?
Thanks,
Holger
Carrier82
Re: IP6C11-P3 configuration?
Post by Carrier82 »
Does the camera work without Internet Explorer (ActiveX)? If not, probably quite impossible to use in ZM. If works in other browsers, try resolving the path the browser uses and use it in monitor settings.
GalenCox
Post by GalenCox »
Thank you for the fast reply.
It looks like the camera only works with IE (ActiveX) so far.
But with the camera they deliver a (very buggy) program. There I got a stream form the camera. But I guest this didnt help as well.
