HI! I did not know English! I'm Russian!
I can not run ZM, installed at the repository!
Linux Dibian!
foscam fi8904w!
Please help! Where to start?
zm 1.24.2
Do not run
Do not run
- Безымянный.jpg (51.2 KiB) Viewed 2306 times
Re: Do not run
1. Make sure you can view your camera on your web browser
2. Do you use a Username / Password to sign in? If you do, then add it to your Remote Host Name?
Example: admin:password@192.168.0.1
Good luck!
Good luck!
Aelingil: I need to waste my time, my clients time and another techs time, just to fix a problem with you server & filters?
Tech Joseph: Yes, you are correct.
