Can't not click Monitor -- ubuntu 12.04
pxd
Post by pxd »
I reinstall my computer. Before Zoneminder is working fine in my ubuntu 12.04.
Now, It's same. but Zoneminder not work.
I use apt-get install zoneminder.
The camera test ok, use mplayer. It work fine.
In Zoneminder, I added monitor-1. It semm work, but can't not click Monitor-1 to view stream.
Can you help me?
the picture
the picture
2012-09-04 10_18_06.png (81.08 KiB) Viewed 5751 times
PacoLM
Re: Can't not click Monitor -- ubuntu 12.04
Post by PacoLM »
Your Zoneminder is stopped, this is why you cannot see the monitor...
pxd
Post by pxd »
I had do to change the status, but it's not working.
In logs, error is none. and can see monitor is running.
I don't know why?
snake61
Post by snake61 »
Did you ever get a resolution? Seems they left you hanging, but that's normal.
Thanks for all the Help.
New to Linux
pxd
Post by pxd »
snake61 wrote:Did you ever get a resolution? Seems they left you hanging, but that's normal.
It still not working. I think maybe i install iRedmail ocurse this problem.
Can you help me?
pxd
Post by pxd »
Last time, I had installed Zoneminder in ubuntu. It's working very well.
But I not Install web application. I think the Postfix(iRedmail) change the
environment.So effect the Zoneminder.
biologisch
Post by biologisch »
Check your cgi-bin path is correct and enough memory is installed.
Greets,
biologisch
ZM Versions = 1.36.33
zmeventnotification Version = "6.1.28"
pxd
Post by pxd »
biologisch wrote:Check your cgi-bin path is correct and enough memory is installed.
Greets,
biologisch
This /etc/zm/zm.conf. I don't change any thing.
# ZoneMinder Base Configuration, $Date: 2008-07-25 10:48:16 +0100 (Fri, 25 Jul 2008) $, $Revision: 2612 $
# This file is generated by 'configure'. Care should be taken if manually
# editing this file as an changes may be overwritten by subsequent configuration
# or installations.
# Current version of ZoneMinder
ZM_VERSION=1.25.0
# Path to build directory, used mostly for finding DB upgrade scripts
ZM_PATH_BUILD=/build/buildd/zoneminder-1.25.0
# Build time, used to record when to trigger various checks
ZM_TIME_BUILD=1329063497
# Path to ZoneMinder binaries
ZM_PATH_BIN=/usr/bin
# Path to ZoneMinder libraries (none at present, for future use)
ZM_PATH_LIB=/usr/lib
# Path to ZoneMinder configuration (this file only at present)
ZM_PATH_CONF=/etc/zm
# Path to ZoneMinder web files
ZM_PATH_WEB=/usr/share/zoneminder
# Path to ZoneMinder cgi files
ZM_PATH_CGI=/usr/lib/cgi-bin
# Username and group that web daemon (httpd/apache) runs as
ZM_WEB_USER=www-data
ZM_WEB_GROUP=www-data
# ZoneMinder database hostname or ip address
ZM_DB_HOST=localhost
# ZoneMinder database name
ZM_DB_NAME=zm
# ZoneMinder database user
ZM_DB_USER=zmuser
# ZoneMinder database password
ZM_DB_PASS=zmpass
biologisch
pls post # top
biologisch
or other question: can you start zoneminder manually?
pxd
Post by pxd »
biologisch wrote:pls post # top
Your meas is let me run top command?
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
2352 www-data 20 0 177m 60m 50m R 57 1.5 2:29.27 zma
2348 www-data 20 0 186m 66m 57m R 22 1.7 0:51.25 zmc
11 root 20 0 0 0 0 S 15 0.0 0:19.19 kworker/0:1
1584 root 20 0 65184 46m 11m S 2 1.1 0:13.10 Xorg
3203 pxd 20 0 93752 15m 11m S 2 0.4 0:00.43 gnome-terminal
246 root 20 0 0 0 0 S 0 0.0 0:00.22 kworker/2:2
2296 www-data 20 0 26684 7280 1744 S 0 0.2 0:00.25 zmdc.pl
2750 pxd 20 0 269m 101m 33m S 0 2.5 0:07.64 compiz
3268 pxd 20 0 2836 1180 860 R 0 0.0 0:00.17 top
1 root 20 0 3516 1928 1252 S 0 0.0 0:00.61 init
2 root 20 0 0 0 0 S 0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0 0.0 0:00.01 ksoftirqd/0
4 root 20 0 0 0 0 S 0 0.0 0:00.00 kworker/0:0
6 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/0
7 root RT 0 0 0 0 S 0 0.0 0:00.04 watchdog/0
8 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/1
9 root 20 0 0 0 0 S 0 0.0 0:00.00 kworker/1:0
10 root 20 0 0 0 0 S 0 0.0 0:00.01 ksoftirqd/1
12 root RT 0 0 0 0 S 0 0.0 0:00.00 watchdog/1
13 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/2
14 root 20 0 0 0 0 S 0 0.0 0:00.00 kworker/2:0
15 root 20 0 0 0 0 S 0 0.0 0:00.08 ksoftirqd/2
16 root RT 0 0 0 0 S 0 0.0 0:00.00 watchdog/2
17 root 0 -20 0 0 0 S 0 0.0 0:00.00 cpuset
18 root 0 -20 0 0 0 S 0 0.0 0:00.00 khelper
19 root 20 0 0 0 0 S 0 0.0 0:00.00 kdevtmpfs
20 root 0 -20 0 0 0 S 0 0.0 0:00.00 netns
22 root 20 0 0 0 0 S 0 0.0 0:00.00 sync_supers
23 root 20 0 0 0 0 S 0 0.0 0:00.00 bdi-default
24 root 0 -20 0 0 0 S 0 0.0 0:00.00 kintegrityd
25 root 0 -20 0 0 0 S 0 0.0 0:00.00 kblockd
26 root 0 -20 0 0 0 S 0 0.0 0:00.00 ata_sff
27 root 20 0 0 0 0 S 0 0.0 0:00.00 khubd
28 root 0 -20 0 0 0 S 0 0.0 0:00.00 md
pxd
Post by pxd »
biologisch wrote:or other question: can you start zoneminder manually?
$ sudo service zoneminder status
ZoneMinder is running
And I try to change status to start, but not effect.
