[SOLVE][PLEASE HELP] How to capture or record to video files
shezars
Post by shezars »
Maybe this is a dumb question , but please help my problem T_T
Can zoneminder result of record in video format (like .avi, .mp4, or else) when we use motion, recording or anything but not using generate to video , so i can copy that file (video file) via USB or others devices in server zoneminder , as we know path folder zoneminder is like this :
The pictures is on attachment (see the result is .jpg not video file)
That's all , thanks very much if somebody have any suggestion or experience with this problem :D
capture_004.tiff
capture_004.tiff (27.48 KiB) Viewed 2229 times
Just a fool which curious
Christo
Re: [PLEASE HELP] How to capture or record to video files
Post by Christo »
Hello shezars,
It seems that you did not set the "Create video for all matches" option within the filter menu that generated these jpg's.
But this will only generate a video for each separate event!!
Goodluck and regards, Christo
shezars
Post by shezars »
Christo wrote:Hello shezars,
Thanks so much christo , there is more optionally in filter mode that can be used to control anything like record to video after using / event record session.. thanks
