BT878 4 Inputs Card - Blank images on certain inputs
tavo1976
Post by tavo1976 »
Hello Everyone,
I am using one BT878 (conextant fusion 878A based) 4 inputs card on an Ubuntu 12.04 server version. I have a problem to watch video from several inputs of BT878 card. I can only watch video from channel/input 0. For all the rest channels/inputs I only watch a black image which includes date and hour information. I had followed all the suggestions of the Pico2000 wiki but it did not work.
These are the screens that I can watch:
Screen shot channel input 1
screen input one.png (33.22 KiB) Viewed 1246 times
Screen shot channel input 0
screen input zero.png (130.84 KiB) Viewed 1246 times
Can someone guide / help me to figure out the answer to my problem?
These are the outputs that I get from the following commands:
lspci -s 01:06 -v
01:06.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 64, IRQ 19
Memory at dcfff000 (32-bit, prefetchable)
Capabilities: <access denied>
Kernel driver in use: bttv
Kernel modules: bttv
01:06.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 64, IRQ 11
Memory at dcffe000 (32-bit, prefetchable)
dmesg | grep bttv
[ 10.791802] bttv: driver version 0.9.19 loaded
[ 10.791805] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 10.798701] bttv: Bt8xx card found (0)
[ 10.798915] bttv 0000:01:06.0: PCI INT A -> Link[LNKA] -> GSI 19 (level, low) -> IRQ 19
[ 10.798928] bttv: 0: Bt878 (rev 17) at 0000:01:06.0, irq: 19, latency: 64, mmio: 0xdcfff000
[ 10.798945] bttv: 0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
[ 10.799065] bttv: 0: tuner absent
[ 10.799158] bttv: 0: registered device video0
[ 10.799220] bttv: 0: registered device vbi0
[ 10.799240] bttv: 0: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[ 10.828039] bttv: PLL set ok
[ 91.430825] bttv: 0: PLL can sleep, using XTAL (28636363)
zmu -d /dev/video0 -q -v
Video Device: /dev/video0
General Capabilities
Driver: bttv
Card: BT878 video (GrandTec Multi Cap
Bus: PCI:0000:01:06.0
Version: 3.2.21
Type: 0x5000015
Supports video capture (X)
Does not support video output
Supports frame buffer overlay
Supports VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
NTSC
NTSC-M
NTSC-M-JP
NTSC-M-KR
PAL
PAL-BG
PAL-H
PAL-I
PAL-DK
PAL-M
PAL-N
PAL-Nc
PAL-60
SECAM
SECAM-B
SECAM-G
SECAM-H
SECAM-DK
SECAM-L
SECAM-Lc
Formats:
8 bpp, gray (GREY)
8 bpp, dithered color (HI24)
15 bpp RGB, le (RGBO)
15 bpp RGB, be (RGBQ)
16 bpp RGB, le (RGBP)
16 bpp RGB, be (RGBR)
24 bpp RGB, le (BGR3)
32 bpp RGB, le (BGR4)
32 bpp RGB, be (RGB4)
4:2:2, packed, YUYV (YUYV)
4:2:2, packed, UYVY (UYVY)
4:2:2, planar, Y-Cb-Cr (422P)
4:2:0, planar, Y-Cb-Cr (YU12)
4:2:0, planar, Y-Cr-Cb (YV12)
4:1:1, planar, Y-Cb-Cr (411P)
4:1:0, planar, Y-Cb-Cr (YUV9)
4:1:0, planar, Y-Cr-Cb (YVU9)
Crop Capabilities
Bounds: 838 x 504
Default: 768 x 480
Current: 768 x 480
Inputs: 4
Input 0
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
Input 1
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 2
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Input 3
Type: Camera
Audioset: 00000001
Standards: 0xffbfff
Power on (X)
Signal detected (X)
Best regards.
Gustavo
