zmcontrol not working
athorretto
Post by athorretto » Tue Jul 31, 2012 4:41 pm
Hi All,
i'm having some problems to get properly work the camera control FoscamFI8918W
OS: Ubuntu 11.10
Zm Version: 1.24.4
I followed instructions found here: http://www.zoneminder.com/wiki/index.php/Foscam_FI8918W
I Recieve an error when i push some button on the gui for move the camera but this type of error i think is not the issue.
The real problem can be found in /var/log/zm/zmcontrol.log:
ZoneMinder::Debug::Fatal('Can\'t connect: File or directory does not exist') called at /usr/bin/zmcontrol.pl line 15
running an strace of zmcontrol i can see that the error is referred to the sock directory: /tmp/zm
poll([{fd=3, events=POLLIN|POLLPRI}], 1, 0) = 0 (Timeout)
write(3, "\21\0\0\0\3set autocommit=1", 21) = 21
read(3, "\7\0\0\1\0\0\0\2\0\0\0", 16384) = 11
socket(PF_FILE, SOCK_STREAM, 0)         = 4
ioctl(4, SNDCTL_TMR_TIMEBASE or TCGETS, 0xbfb88dac) = -1 ENOTTY (Inappropriate ioctl for device)
_llseek(4, 0, 0xbfb88df0, SEEK_CUR)     = -1 ESPIPE (Illegal seek)
fcntl64(4, F_SETFD, FD_CLOEXEC)         = 0
connect(4, {sa_family=AF_FILE, path="/tmp/zm/zmcontrol-1.sock"}, 110) = -1 ENOENT (No such file or directory)
time(NULL)                              = 1343727472
rt_sigprocmask(SIG_BLOCK, [CHLD], [], 8) = 0
rt_sigaction(SIGCHLD, NULL, {SIG_DFL, [], 0}, 8) = 0
rt_sigprocmask(SIG_SETMASK, [], NULL, 8) = 0
nanosleep({1, 0}, {0, 995771137})       = ? ERESTART_RESTARTBLOCK (To be restarted)
--- SIGCHLD (Child exited) @ 0 (0) ---
restart_syscall(<... resuming interrupted call ...>) = 0
time(NULL)                              = 1343727473
nanosleep({1, 0}, ^C <unfinished ...>
and then it retry giving the same output.
I checked the forum for a solution, also googled.... nothing.
I also tried to update to 1.25.0 with same results.
some details.
root@zm:/# ls -la  | grep tmp
drwxrwxrwx   5 root     root      4096 2012-07-31 11:39 tmp
root@zm:/# ls -la /tmp
totale 20
drwxrwxrwx  5 root     root     4096 2012-07-31 11:39 .
drwxr-xr-x 23 root     root     4096 2012-07-31 10:04 ..
drwxrwxrwx  2 root     root     4096 2012-07-29 11:51 .ICE-unix
drwxrwxrwx  2 root     root     4096 2012-07-29 11:51 .X11-unix
drwx------  4 www-data www-data 4096 2012-07-31 11:32 zm
root@zm:/#
root@zm:/tmp/zm# pwd
/tmp/zm
root@zm:/tmp/zm# ls -la
totale 16
drwx------ 4 www-data www-data 4096 2012-07-31 11:32 .
drwxrwxrwx 5 root     root     4096 2012-07-31 11:39 ..
srwxr-xr-x 1 www-data www-data    0 2012-07-31 11:15 zmdc.sock
drwxr-xr-x 2 www-data www-data 4096 2012-07-31 11:32 zmswap-m1
drwxr-xr-x 2 www-data www-data 4096 2012-07-31 10:32 zmswap-m2
root@zm:/tmp/zm#
Anyone can help?
Thanks!
TylerSchwend
Re: zmcontrol not working
Post by TylerSchwend » Sun Sep 02, 2012 3:09 pm
Sorry for the late response... Running 1.24 of ZoneMinder, you need to have the "Debug" line uncommented and make sure there are no "Logger" lines in your control script. It should look like this, (Or have the logger line omitted entirely).
#use ZoneMinder:Logger qw(:all);
dma_k
Post by dma_k » Sun Jan 20, 2013 8:09 pm
TylerSchwend wrote:Sorry for the late response... Running 1.24 of ZoneMinder, you need to have the "Debug" line uncommented and make sure there are no "Logger" lines in your control script. It should look like this, (Or have the logger line omitted entirely).
I have another information: use ZoneMinder:Logger and comment out ZoneMinder::Debug for ZoneMinder v1.25:
Can't locate ZoneMinder/Debug.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl) at /usr/share/perl5/ZoneMinder/Control/Foscam.pm line 45.
I think the script /usr/bin/zmcontrol.pl is missing the check for error; something like:
load "ZoneMinder::Control::$protocol";
if ($@)
 Fatal("Cannot load control module: $@");
Users browsing this forum: No registered users and 6 guests
