ZM 1.25 and FOSCAM FI8905W CONNECTION ISSUES
FURBY
Post by FURBY »
I'm trying to connect Foscam FI8905W cam to ZM 1.5 on a Centos 6.2, following all the indications in the model specific wiki but I still have "Unable to probe network cameras, status is '255'", red indication of the source in the main page and no way to solve it. The stream is visible elsewhere for example using ffmpeg so I think could be something wrong somewhere in zm configuration. Looking at the log I can see "Connection dropped by remote end", "Unable to capture image, retrying" and after these two or more entries like "Capturing at 3.95 fps" and after that "Select timed out", all in sequence and then again "Connection dropped by remote end" and so on from the beginning. Any idea about this strange behaviour? Many thanks in advance for every suggestion.
FURBY
Re: ZM 1.25 and FOSCAM FI8905W CONNECTION ISSUES
Post by FURBY »
No ideas? Nobody have experienced the same issue or something similar?
FURBY
Re:[SOLVED] ZM 1.25 and FOSCAM FI8905W CONNECTION ISSUES
Post by FURBY »
Finally I've solved: SELINUX in enforcing mode can cause strange issues.
