Error: expected 328, got 316
Hi all,
Thanks for your help in advance. I have set up a new Ubuntu 12.04 system running Zoneminder 1.25.0. I have a 16 channel, 8 chip BT878 card which is detected by the system. I am able to add monitors (have added from video0 to video7, assuming the remaining 8 will be accessible by using channels). I get black screens with time stamps for all monitors.
I would like to replace the current XP CCTV system with Zoneminder as it served me well in the past.
I am not sure if the errors below from the log are the cause:
2012-06-26 15:42:58.713420 zmwatch[2406].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Monitor-8, expected 328, got 316]
2012-06-26 15:42:58.714660 zmwatch[2406].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Monitor-7, expected 328, got 316]
2012-06-26 15:42:58.715550 zmwatch[2406].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Monitor-6, expected 328, got 316]
2012-06-26 15:42:58.716410 zmwatch[2406].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Monitor-5, expected 328, got 316]
2012-06-26 15:42:58.717230 zmwatch[2406].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Monitor-4, expected 328, got 316]
2012-06-26 15:42:58.718240 zmwatch[2406].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Monitor-3, expected 328, got 316]
2012-06-26 15:42:58.719180 zmwatch[2406].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Monitor-2, expected 328, got 316]
2012-06-26 15:42:58.720030 zmwatch[2406].ERR-zmwatch.pl [Shared data size conflict in shared_data for monitor Monitor-1, expected 328, got 316]
2012-06-26 15:43:00.827460 zmdc[2366].WAR-zmdc.pl [Can't find process with command of 'zmc -d /dev/video7']
2012-06-26 15:43:01.090930 zmdc[3066].INF-zmdc.pl ['zmc -d /dev/video7' started at 12/06/26 15:43:01]
2012-06-26 15:43:01.091100 zmdc[2366].INF-zmdc.pl ['zmc -d /dev/video7' starting at 12/06/26 15:43:01, pid = 3066]
2012-06-26 15:43:01.175695 zmc_dvideo7[3066].INF-zmc.cpp/191 [Starting Capture]
2012-06-26 15:43:01.398550 zmdc[2366].WAR-zmdc.pl [Can't find process with command of 'zma -m 16']
2012-06-26 15:43:04.380017 zmc_dvideo4[2886].INF-zm_monitor.cpp/2598 [Monitor-5: 4000 - Capturing at 30.30 fps]
2012-06-26 15:43:05.070010 zmdc[2366].INF-zmdc.pl [Starting pending process, zmc -d /dev/video8]
2012-06-26 15:43:05.075800 zmdc[2366].INF-zmdc.pl ['zmc -d /dev/video8' starting at 12/06/26 15:43:05, pid = 3084]
2012-06-26 15:43:05.075810 zmdc[3084].INF-zmdc.pl ['zmc -d /dev/video8' started at 12/06/26 15:43:05]
2012-06-26 15:43:05.124576 zmc_dvideo8[3084].ERR-zmc.cpp/187 [No monitors found]
2012-06-26 15:43:05.127610 zmdc[2366].ERR-zmdc.pl ['zmc -d /dev/video8' exited abnormally, exit status 255]
2012-06-26 15:43:05.496426 zmc_dvideo5[2932].INF-zm_monitor.cpp/2598 [Monitor-6: 3000 - Capturing at 30.30 fps]
2012-06-26 15:43:06.604332 zmc_dvideo3[2841].INF-zm_monitor.cpp/2598 [Monitor-4: 5000 - Capturing at 30.30 fps]
Thanks,
Thanks,
Re: Error: expected 328, got 316
Known issue, find your /Zoneminder/Memory.pm and replace:
with
Hope it helps,
PacoLM
$arch = int(3.2*length(~0));
$arch = 32;
PacoLM
Thanks PacoLM,
That solved those errors, however, I am still not able to get a feed from any of my monitors, only a black screen with time stamp.
Should I start a new thread for this? It does take a while for all /dev/video devices to be available. A snippet of the log is below.
2012-06-27 15:36:49.817130 zms[2764].INF-zm_signal.cpp/44 [Got signal 15 (Terminated), exiting]
2012-06-27 15:36:51.556553 zms[2769].INF-zm_user.cpp/231 [Authenticated user 'nasi']
2012-06-27 15:36:52.075614 zms[2769].ERR-zm_monitor.cpp/3639 [Terminating, last frame sent time 1340804211.575489 secs more than maximum of 10.000000]
2012-06-27 15:36:53.192321 zmc_dvideo2[2591].INF-zm_monitor.cpp/2598 [Monitor-3: 7000 - Capturing at 29.41 fps]
2012-06-27 15:36:53.418502 zmc_dvideo3[2718].INF-zm_monitor.cpp/2598 [Monitor-4: 4000 - Capturing at 30.30 fps]
2012-06-27 15:36:53.433540 zmc_dvideo4[2717].INF-zm_monitor.cpp/2598 [Monitor-5: 4000 - Capturing at 30.30 fps]
2012-06-27 15:36:53.448341 zmc_dvideo6[2720].INF-zm_monitor.cpp/2598 [Monitor-7: 4000 - Capturing at 30.30 fps]
2012-06-27 15:36:53.456002 zmc_dvideo5[2719].INF-zm_monitor.cpp/2598 [Monitor-6: 4000 - Capturing at 30.30 fps]
2012-06-27 15:36:54.009797 zmc_dvideo0[2516].INF-zm_monitor.cpp/2598 [Monitor-1: 8000 - Capturing at 29.41 fps]
2012-06-27 15:36:55.146915 zms[2773].INF-zm_user.cpp/231 [Authenticated user 'nasi']
2012-06-27 15:36:57.342792 zms[2773].INF-zm_signal.cpp/44 [Got signal 15 (Terminated), exiting]
2012-06-27 15:37:21.970821 zmc_dvideo1[2664].INF-zm_monitor.cpp/2598 [Monitor-2: 7000 - Capturing at 30.30 fps]
2012-06-27 15:37:26.570027 zmc_dvideo2[2591].INF-zm_monitor.cpp/2598 [Monitor-3: 8000 - Capturing at 30.30 fps]
2012-06-27 15:37:26.796189 zmc_dvideo3[2718].INF-zm_monitor.cpp/2598 [Monitor-4: 5000 - Capturing at 30.30 fps]
2012-06-27 15:37:26.811259 zmc_dvideo4[2717].INF-zm_monitor.cpp/2598 [Monitor-5: 5000 - Capturing at 30.30 fps]
2012-06-27 15:37:26.826020 zmc_dvideo6[2720].INF-zm_monitor.cpp/2598 [Monitor-7: 5000 - Capturing at 30.30 fps]
2012-06-27 15:37:26.833665 zmc_dvideo5[2719].INF-zm_monitor.cpp/2598 [Monitor-6: 5000 - Capturing at 30.30 fps]
2012-06-27 15:37:27.387461 zmc_dvideo0[2516].INF-zm_monitor.cpp/2598 [Monitor-1: 9000 - Capturing at 30.30 fps]
2012-06-27 15:37:55.348533 zmc_dvideo1[2664].INF-zm_monitor.cpp/2598 [Monitor-2: 8000 - Capturing at 29.41 fps]
2012-06-27 15:37:59.947667 zmc_dvideo2[2591].INF-zm_monitor.cpp/2598 [Monitor-3: 9000 - Capturing at 30.30 fps]
2012-06-27 15:38:00.174360 zmc_dvideo3[2718].INF-zm_monitor.cpp/2598 [Monitor-4: 6000 - Capturing at 29.41 fps]
2012-06-27 15:38:00.188906 zmc_dvideo4[2717].INF-zm_monitor.cpp/2598 [Monitor-5: 6000 - Capturing at 29.41 fps]
2012-06-27 15:38:00.203726 zmc_dvideo6[2720].INF-zm_monitor.cpp/2598 [Monitor-7: 6000 - Capturing at 29.41 fps]
2012-06-27 15:38:00.211419 zmc_dvideo5[2719].INF-zm_monitor.cpp/2598 [Monitor-6: 6000 - Capturing at 29.41 fps]
2012-06-27 15:38:00.765181 zmc_dvideo0[2516].INF-zm_monitor.cpp/2598 [Monitor-1: 10000 - Capturing at 30.30 fps]
Thanks again for any help in advance.
In order to debug the system, only enable one monitor and disable (not delete) the rest. Once you get the feed from one camera it's easier to get all.
Try lowering the FPS for all cameras to don't overload the system. Once it's working you could increase it again.
Worth to try: Uncheck V4L_MULTI_BUFFER and set CAPTURES_PER_FRAME to 2
Also, check you shared memory settings (if you are using it): http://www.zoneminder.com/forums/viewto ... ory#p72552
Post results, hope it helps!
Thanks for the suggestions. I tried all of them but none have helped. I have disabled all monitors except Monitor-4 running on dev/video3 with log below. Screenshot on montage view attached.
2012-06-28 11:04:48.625105 zmc_dvideo3 2666 INF Monitor-4: 2000 - Capturing at 30.30 fps zm_monitor.cpp 2598
2012-06-28 11:04:38.951777 zmc_dvideo1 2467 INF Monitor-2: 1000 - Capturing at 3.01 fps zm_monitor.cpp 2598
2012-06-28 11:04:38.500744 zmc_dvideo2 2463 INF Monitor-3: 1000 - Capturing at 3.00 fps zm_monitor.cpp 2598
2012-06-28 11:04:37.750072 zmc_dvideo4 2455 INF Monitor-5: 1000 - Capturing at 3.00 fps zm_monitor.cpp 2598
2012-06-28 11:04:15.264024 zmc_dvideo3 2666 INF Monitor-4: 1000 - Capturing at 29.41 fps zm_monitor.cpp 2598
2012-06-28 11:04:14.742111 web_js 2094 ERR rows is undefined javascript/mootools/mootools-more-nc.js 9370
2012-06-28 11:03:47.077348 zms 2685 INF Got signal 15 (Terminated), exiting zm_signal.cpp 44
2012-06-28 11:03:45.734112 zms 2685 INF Authenticated user 'admin' zm_user.cpp 231
2012-06-28 11:03:42.002200 zmdc 2414 WAR Can't find process with command of 'zma -m 12' zmdc.pl
2012-06-28 11:03:41.818669 zmc_dvideo3 2666 INF Starting Capture zmc.cpp 191
2012-06-28 11:03:41.735360 zmdc 2414 INF 'zmc -d /dev/video3' starting at 12/06/28 11:03:41, pid = 2666 zmdc.pl
2012-06-28 11:03:41.735170 zmdc 2666 INF 'zmc -d /dev/video3' started at 12/06/28 11:03:41 zmdc.pl
2012-06-28 11:03:41.473650 zmdc 2414 INF 'zmc -d /dev/video3' exited normally zmdc.pl
2012-06-28 11:03:41.411396 zmc_dvideo3 2459 INF Got signal 15 (Terminated), exiting zm_signal.cpp 44
2012-06-28 11:03:41.410400 zmdc 2414 INF 'zmc -d /dev/video3' stopping at 12/06/28 11:03:41 zmdc.pl
2012-06-28 11:03:36.615100 zms 2650 INF Got signal 15 (Terminated), exiting zm_signal.cpp 44
2012-06-28 11:03:34.966825 zms 2650 INF Authenticated user 'admin' zm_user.cpp 231
2012-06-28 11:03:32.328466 zmc_dvideo3 2459 INF Monitor-4: 8000 - Capturing at 29.41 fps zm_monitor.cpp 2598
2012-06-28 11:03:31.596795 zmc_dvideo0 2631 INF Starting Capture zmc.cpp 191
- Screenshot.png (21.83 KiB) Viewed 8198 times
Turn the lights on!
Seems that some package is not the latest one, run :
apt-get update && apt-get dist-upgrade
System is up to date, but still the same issue. Any further suggestions?
I assume that xawtv doesn't get any picture either.
It might be that your system isn't detecting the correct video card. You should be able to see what card it is using by looking at the output from dmesg.
Below is a section of dmesg:
[ 335.112156] bttv: 6: using: IVC-200 [card=102,insmod option]
[ 335.112210] bt878 #6 [sw]: bus seems to be busy (scl=0, sda=0)
[ 335.916139] bttv: 6: tuner absent
[ 335.916146] bttv: 6: the autoload option is obsolete
[ 335.916150] bttv: 6: use option msp3400, tda7432 or tvaudio to override which audio module should be used
[ 335.916317] bttv: 6: registered device video6
[ 335.916423] bttv: 6: registered device vbi6
[ 335.916452] bttv: 6: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[ 335.948019] bttv: PLL set ok
[ 359.878752] bttv: 5: PLL can sleep, using XTAL (28636363)
[ 359.896955] bttv: 4: PLL can sleep, using XTAL (28636363)
[ 360.847223] bttv: 2: PLL can sleep, using XTAL (28636363)
[ 360.853684] bttv: 3: PLL can sleep, using XTAL (28636363)
[ 361.967684] usb 5-2.2: USB disconnect, device number 5
[ 362.875307] bttv: 0: PLL can sleep, using XTAL (28636363)
[ 363.368016] bttv: 0: timeout: drop=7 irq=9318/10615, risc=1bc44024, bits: HSYNC FDSR
[ 367.289350] usb 5-2.2: new low-speed USB device number 6 using uhci_hcd
[ 367.426589] input: HID 0566:3107 as /devices/pci0000:00/0000:00:10.3/usb5/5-2/5-2.2/5-2.2:1.0/input/input9
[ 367.426827] generic-usb 0003:0566:3107.0008: input,hidraw2: USB HID v1.10 Keyboard [HID 0566:3107] on usb-0000:00:10.3-2.2/input0
[ 367.449626] input: HID 0566:3107 as /devices/pci0000:00/0000:00:10.3/usb5/5-2/5-2.2/5-2.2:1.1/input/input10
[ 367.449824] generic-usb 0003:0566:3107.0009: input,hidraw3: USB HID v1.10 Device [HID 0566:3107] on usb-0000:00:10.3-2.2/input1
[ 368.108052] bttv: Bt8xx card found (7)
[ 368.108082] bttv 0000:02:0f.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 368.108102] bttv: 7: Bt878 (rev 17) at 0000:02:0f.0, irq: 17, latency: 32, mmio: 0xe200e000
[ 368.108177] bttv: 7: using: IVC-200 [card=102,insmod option]
[ 368.108235] bt878 #7 [sw]: bus seems to be busy (scl=0, sda=0)
[ 368.912145] bttv: 7: tuner absent
[ 368.912152] bttv: 7: the autoload option is obsolete
[ 368.912156] bttv: 7: use option msp3400, tda7432 or tvaudio to override which audio module should be used
[ 368.912346] bttv: 7: registered device video7
[ 368.912440] bttv: 7: registered device vbi7
[ 368.912471] bttv: 7: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[ 368.915038] bttv: 7: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[ 368.915537] bttv: 7: Setting PLL: 28636363 => 35468950 (needs up to 100ms)
[ 368.928032] bttv: PLL set ok
[ 368.928066] bttv: PLL set ok
[ 368.944139] bttv: PLL set ok
It is identifying your card as an IVC-200 (card number 102). Have you checked the documentation that came with your card to verify that this is correct?
I see from the original post that each BT878 handles 2 video channels. Have you tried different device channel numbers? I have come across one card that didn't start the device channel numbering at 0.
The only other thing I can see is this;
which I have no idea whether it is a problem or not but you might try searching hardware forums to find out if it is.[ 368.108235] bt878 #7 [sw]: bus seems to be busy (scl=0, sda=0)
I have tried the video channels up to about 20 (there are 32) and got the same result. I will try them all tomorrow.
I am not sure what video card is installed as the PC came with the card installed and no supporting documents. Windows XP also recognises the card with the generic driver so I do not think I am able to get any more info from there.
Would the card physically have any info printed on it?
It is possible the card might have something on it to allow you to identify it. Have a look see what you can find.
You could also post the output of:
This might allow someone to identify the card.lspci -nns 0000:02:0f.0
