Ovislink POE-250HD and ZM 1.25 on Centos 6.2_64 PROBLEM !:(
GoldiBoy
Post by GoldiBoy »
Hello !
For two months I am trying to setup two cameras Ovislink OD-2025HD and POE-250HD. I was reinstaling entire system maybe 10 times compiling couples od ffmpeg,s 0.6.5 0.8.12, 0.10x and I have such an image. image is blurred on halfway but on direct access to the camera is ok. Also VLC Player show good images on all too cameras profiles. I was tried all settings on camera (GOP, CBR, VBR) and I have on ZM such a view. Only o ZM all players show perfect images. I have ZM 1.25 on Centos 6.2 64bit, server HP XW6400, 4 GB RAM, 1x Intel Xeon L5320 quad core CPU. The same thing with Ovis OD-2025. I use direcly RTSP Source in ZM like rtsp://admin:airlive@192.168.1.106:554/media.amp?videocodec=h264&resolution=sxga. Please help me. Sorry for my english I am from Poland... :)
Regards,
image from ZM
image from ZM
from ZM.jpg (193.96 KiB) Viewed 4193 times
image from camera is perfect, all browsers, all profiles...
from camera.jpg (247.2 KiB) Viewed 4193 times
macropin
Re: Ovislink POE-250HD and ZM 1.25 on Centos 6.2_64 PROBLEM
Post by macropin »
Sounds like a similar issue I hit with our Geovision cams... See ffmpeg<dot>org<slash>trac<slash>ffmpeg<slash>ticket<slash>285 (I had to break the url because I'm a new user and not allowed to post links)
You are right to be suspicious of ffmpeg. As far as I can tell RTSP support in FFMPEG is extremely buggy.
Have you tried prepending "?tcp" to the connection string? The "?tcp" suffix is an argument parsed and recognized by ffmpeg to not use udp. That resolved the issue for me with my cams.
GoldiBoy
Post by GoldiBoy »
ThankYou for advice, where I must add this '?tcp' to string? At the end of string line ?
Thank You,
macropin
Post by macropin »
Yes, at the end of the connection string. Similar to shown here http://www.zoneminder.com/wiki/index.ph ... =Geovision
GoldiBoy
Post by GoldiBoy »
It is working !
Thank You very much :)
Regards,
macropin
Post by macropin »
Cool. Glad I could help :)
Now, if someone would just help me with my question.... http://www.zoneminder.com/forums/viewto ... 29&t=19252
neoncek
Post by neoncek »
@GoldiBoy - may I ask you to share your configuration of OD-2025HD? I am running Ubuntu 13.04 on HP ProLiant Micro Server G7 N54L, ZoneMinder v1.25.0 installed via ubuntu repo. Basic connection with OD-2025HD in default is my issue.
ipcam setting - Video Profile1 - 1080p h264 EVBR 30fps
PS: I`am from Slovakia :)
