enable OPT_USE_AUTH
enable OPT_USE_AUTH
after i enable OPT_USE_AUTH i can not see any output on any camares
- No Auth.jpg (67.35 KiB) Viewed 2916 times
Re: enable OPT_USE_AUTH
Maybe you need to logoff and logon again.
You need to put AUTH_RELAY under System as "none".
Restart ZM.
Thats all.
Restart ZM.
Thats all.
That works for me also. Should I have that as none though? Why doesn't hashed work? I am running Ubuntu 12.04jbaiao wrote:You need to put AUTH_RELAY under System as "none".
Restart ZM.
Thats all.
@ jbaiao - I agree that is one fix, which worked for me right now, but what is probably more concerning is that this doesn't fix the issue, it is lowering the security of the system
