Hi all !
I come here to ask if anyone managed to have the Miro or (Pïnnacle) DC10+ (Zoran Chipset) work with Zoneminder.
This card is detected by my Ubuntu, #lspci shows : Multimedia controller: Pinnacle Systems Inc. Pinnacle AV/DV Studio Capture Card
I found many posts stating that VLC does display the live image, via v4l2, /dev/video0, I'll try this tomorrow...
But can't find any setting that make it work with zoneminder.
Is there an obvious reason for this or should I keep trying ?
many thanks
cheers
Vince
Miro DC10+ / Support
Re: Miro DC10+ / Support
found the info that this card does not work on ubuntu since ubuntu 9.10....
will try another linux then and keep you posted
