Hello all,
I would like to get Zoneminder running with an Axis P7210 video network server which connects 16 analog cams. I had a look at the Axis user manual and it says that the stream can be accessed via <ip>/axis-cgi/jpg/image.cgi. However, it does not say how to get to the individual streams. 4 analog ports are connected to one LAN port and you can set a quad view image on each port and then record that if I understand the manual correctly. However, is it possible to stram each of the cameras individually? I would like to know before I buy one so I won't be dissappointed. Thanks for any advice in advance.
