Zones preview windows does not appear(modest & montage work)
Schuhkasten
Post by Schuhkasten »
Hello
Iam now running zoneminder 1.24.2 under Ubuntu 10.04 (before 9.04 worked fine).
Actually 2 remote cams are working fine but the preview window where you define the zones does not show a content.
Also clicking on a zone itself to define the content only show a white empty area...
Clicking directly on the cam it works or the montage views also...
Concerning the logs I have not found a error under /tmp/...
joern@ubuntu:/tmp$ cat zm*
02/05/12 11:24:46.997212 zmdc[1358].INF [Server starting at 12/02/05 11:24:46]
02/05/12 11:24:52.855898 zmdc[1358].INF ['zmc -m 1' starting at 12/02/05 11:24:52, pid = 1608]
02/05/12 11:24:54.760224 zmdc[1358].INF ['zma -m 1' starting at 12/02/05 11:24:54, pid = 1624]
02/05/12 11:24:56.623924 zmdc[1358].INF ['zmc -m 2' starting at 12/02/05 11:24:56, pid = 1639]
02/05/12 11:24:57.684612 zmdc[1358].INF ['zma -m 2' starting at 12/02/05 11:24:57, pid = 1644]
02/05/12 11:24:58.548841 zmdc[1358].INF ['zmfilter.pl' starting at 12/02/05 11:24:58, pid = 1648]
02/05/12 11:25:00.052883 zmdc[1358].INF ['zmaudit.pl -c' starting at 12/02/05 11:25:00, pid = 1651]
02/05/12 11:25:01.134706 zmdc[1358].INF ['zmwatch.pl' starting at 12/02/05 11:25:01, pid = 1653]
cat: zmdc.sock: No such device or address
02/05/12 11:25:00.632225 zmfilter[1648].INF [Scanning for events]
02/05/12 11:24:43.988016 zmpkg[1136].INF [Command: start]
cat: zmswap-m1: Is a directory
02/05/12 11:25:02.093881 zmwatch[1653].INF [Watchdog starting]
02/05/12 11:25:02.103569 zmwatch[1653].INF [Watchdog pausing for 30 seconds]
Schuhkasten
Re: Zones preview windows does not appear(modest & montage w
this is how it looks. Does no one has a idea. System work great now but without windows not sooo nice...
teraquad
Post by teraquad »
Did you ever get a reply on this one?
I have the very same problem and am interested in how it turned out.
Thanks!
Fedora 23, ZM 1.28
N4ZPO (ham Radio)
8)
privateer
Post by privateer »
I ran into a similar issue like this after I added a second hard drive. I found that moving preview images didn't work, but if I left the preview images pointing to the original location it would work.
capetownlad
Post by capetownlad »
Hi
I also have this issue and wondered how you guys solved this?
