Slow installing cameras
I have just installed ZM on Ubuntu 10.04 and this is my second reinstall after hitting a few issues. the last one i am having is it takes almost 20 min for the system to install all the CCTV cams to dev/videoXX and then about 10 more minutes for them all to all go green. anyone have any ideas?
Re: Slow installing cameras
Once you have your setup working, install phpmyadmin and do an export of your zm database.
Here it is
i just did a clean re install and it still is doing it takes about 30 mins total still
- localhost.sql.zip
- (31.54 KiB) Downloaded 228 times
I think I've read your first post very quickly. I thought you were complaining about the monitor configuration itself, not ZM being slow. Could you post your /var/log/syslog when starting the application?.
