A ton of "Script error" in log window
Normando
Post by Normando »
Hi Phil.
I am getting a lot of errors in log window every time I open any window (watch, options, etc)
The following is one example:
2011-12-11 15:29:24.475226	web_js	16641	ERR	Script error.	?view=log
and there are times that no show the file (?log.php, or ?watch.php)
What can I do to fix this issue. This error comes from web_js component.
Thank you
Normando
Normando
Re: A ton of "Script error" in log window
Post by Normando »
This is the screen capture.
Log window
Log window
Normando
Post by Normando »
BUMP
Anyone has this issue or only me?
sipi
Post by sipi »
I have same problem. See it:
http://www.zoneminder.com/forums/viewto ... 29&t=18601
I don't know exactly but I think it depends the browser. I usually I use Chrome but I have installed Firefox on my pc. When I connected to zm from Chrome I have same problem but when I use Firefox there isn't any web_js script error in log window.
What do you think is it maybe? Can you try it?
