Null Events
bhildred
Null Events
Post by bhildred »
I am getting a large number of null events. a handful follow.
any Ideas?
137820 New Event 2011-08-10 13:43:50 0.00 null/null 0/0 X
137819 New Event 2011-08-10 13:43:17 0.00 null/null 0/0 X
137816 New Event 2011-08-10 13:42:48 0.00 null/null 0/0 X
137814 New Event 2011-08-10 13:42:19 0.00 null/null 0/0 X
137812 New Event 2011-08-10 13:41:50 0.00 null/null 0/0 X
137811 New Event 2011-08-10 13:41:04 0.00 null/null 0/0 X
PacoLM
Re: Null Events
Post by PacoLM »
Post the logs in /var/log/syslog, the causes could be a bad location of the events directories (do you have an external drive?), corrupted database, and many more.
Hope it helps,
PacoLM
bhildred
Re: Null Events
Post by bhildred »
here is a log file
Edit: is there a file size limit?
PacoLM
Re: Null Events
Post by PacoLM »
It should be, if there are a lot of repeated lines, just put a sample of the errors, not the complete file!
bhildred
Re: Null Events
Post by bhildred »
trying again
messages.zip
(16.86 KiB) Downloaded 204 times
PacoLM
Re: Null Events
Post by PacoLM »
Here is the extract of the log:
Aug 14 04:34:37 server4a zmdc[2833]: INF ['zma -m 12' starting at 11/08/14 04:34:37, pid = 18587]
Aug 14 04:34:37 server4a zmdc[18587]: INF ['zma -m 12' started at 11/08/14 04:34:37]
Aug 14 04:34:37 server4a zmwatch[2878]: INF ['zma -m 12' starting at 11/08/14 04:34:37, pid = 18587]
Aug 14 04:34:37 server4a zma_m12[18587]: INF [Debug Level = 0, Debug Log = <none>]
Aug 14 04:34:37 server4a zma_m12[18587]: INF [In mode 3/1, warming up]
Aug 14 04:34:41 server4a zmc_dvideo2[2863]: INF [yard: 14201000 - Capturing at 30.30 fps]
Aug 14 04:35:07 server4a zma_m7[2865]: INF [yard: 14199000 - Processing at 30.30 fps]
Aug 14 04:35:15 server4a zmc_dvideo2[2863]: INF [yard: 14202000 - Capturing at 29.41 fps]
Aug 14 04:35:24 server4a zmc_dvideo3[2859]: INF [south: 2615000 - Capturing at 5.00 fps]
Aug 14 04:35:36 server4a zma_m8[17443]: INF [south: 158000 - Processing at 4.98 fps]
Aug 14 04:35:40 server4a zma_m7[2865]: INF [yard: 14200000 - Processing at 30.30 fps]
Aug 14 04:35:48 server4a zmc_dvideo2[2863]: INF [yard: 14203000 - Capturing at 30.30 fps]
Aug 14 04:36:06 server4a zma_m12[18587]: INF [Drive: 080 - Gone into alarm state]
Aug 14 04:36:06 server4a zma_m12[18587]: INF [Got signal 6 (Aborted), exiting and forcing backtrace]
Seems that you have the problems in only one monitor (m12). Is it true or the problem is afecting all of them?. If is only affecting this channel, you could try to delete the monitor and create it again, in order to troubleshoot the problem.
Hope it helps,
PacoLM
PacoLM
Re: Null Events
Post by PacoLM »
bhildred
Re: Null Events
Post by bhildred »
bhildred wrote:I am getting a large number of null events. a handful follow.
any Ideas?
Solved : ext2 directory full, switched to deep directory structure
