Triggereing an email from events
kfelgs
Post by kfelgs » Tue Jul 26, 2011 11:34 am
I've setup Zoneminder on Linux Mint 10 and it's working fine. The only problem I have been having is setting up the email triggering. I believe I set it up correctly in the configuration and in the filter, but it doesn't seem to work. I'm trying my use my gmail SMTP server. Is it a problem because it uses server authentication? Any help would be appropriated..
camroidv27
Re: Triggereing an email from events
Post by camroidv27 » Tue Aug 02, 2011 10:57 pm
It may be your ISP. I had that issue on my box. Following the Postfix portion of the following guide (its at the bottom) worked for me. Basically, you'll pump your e-mails through your ISPs SMTP server.
http://www.zoneminder.com/wiki/index.ph ... _Cambozola
