First Post! Keep in mind I am a complete ZM and Linux Newbie. If you can break anyting I missed down step by step it would be much appreciated!
Host OS ESXi4 Guest OS Ubuntu 11.04
ZM 1.24.2
Camera: Foscam FI8918W
IP: 192.168.57.169
Port:8020
URL to view still images http 192.168.57.169:8020 forward slash snapshot.cgi (the site wont let me use urls in the post for some reason)
Remote Host Path in ZM: /snapshot.cgi (does this path need to be a video feed? If so any idea what that path is?)
I have included an image from ZM with all of my settings from ZM and the URL of the static feed.
Foscam IP Camera Setup
- Here is an image of all my settings
- zm05.gif (207.96 KiB) Viewed 2338 times
Re: Foscam IP Camera Setup
I found a helpful post in the wiki here: http://www.zoneminder.com/wiki/index.php/Foscam
I can get it to show up with the following settings:
General
Source Type: Remote
Function: Modect (up to you though)
Enabled: Tick
Maximum FPS: Empty (I had some issues with it lagging when I used values here)
Alarm Maximum FPS: Empty
Source
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: x.x.x.x (The IP of the camera)
Remote Host Port: 80
Remote Host Path: /videostream.cgi?user=admin&pwd= (assuming you have an admin user on the cam with no password)
Capture Width: 320 (You could use 640 x 480, I found 320 to be better)
Capture Height: 240
It will not recognize with a higher resolution though. Any suggestions?
General
Source Type: Remote
Enabled: Tick
Source
Capture Height: 240
If your using shared memory Check your shmall and shmax memory settings. Well covered in the wiki and forums.
Hellow,
Try setting your camera first to 640 x 480 via the settings page on your camera first. Then set this resolution in your zoneminder monitor.
