Randomly not recording
joako
Post by joako »
I have an issue where randomly some camera will stop recording. I can still view it live!
I've looked at the logs and there's nothing relevant.
How can I ensure my cameras are always recording? There's plenty of free disk space.
[   15.190257] type=1505 audit(1308872556.188:11): operation="profile_load" pid=907 name=/usr/sbin/traceroute
[   17.029323] tg3 0000:04:04.0: firmware: requesting tigon/tg3_tso5.bin
[   17.111655] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   20.260806] tg3 0000:04:04.0: eth0: Link is up at 1000 Mbps, full duplex
[   20.260812] tg3 0000:04:04.0: eth0: Flow control is on for TX and on for RX
[   20.261007] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   33.459788] bttv1: PLL can sleep, using XTAL (28636363).
[   35.044408] bttv3: PLL can sleep, using XTAL (28636363).
[  277.602688] NET: Registered protocol family 17
[  726.304866] 3w-9xxx: scsi2: AEN: INFO (0x04:0x0029): Verify started:unit=0.
[ 1251.259485] 3w-9xxx: scsi2: AEN: INFO (0x04:0x003D): Verify paused:unit=0.
[ 1491.242161] 3w-9xxx: scsi2: AEN: INFO (0x04:0x0029): Verify started:unit=0.
[46764.290987] 3w-9xxx: scsi2: AEN: INFO (0x04:0x002B): Verify completed:unit=0.
[47132.515565] 3w-9xxx: scsi2: AEN: INFO (0x04:0x0029): Verify started:unit=0.
[79668.756547] tg3 0000:04:04.0: eth0: Link is down
[79671.679674] tg3 0000:04:04.0: eth0: Link is up at 1000 Mbps, full duplex
[79671.679680] tg3 0000:04:04.0: eth0: Flow control is on for TX and on for RX
[87689.237384] 3w-9xxx: scsi2: AEN: INFO (0x04:0x003D): Verify paused:unit=0.
[87699.435012] 3w-9xxx: scsi2: AEN: INFO (0x04:0x0029): Verify started:unit=0.
[89564.539568] 3w-9xxx: scsi2: AEN: INFO (0x04:0x002B): Verify completed:unit=0.
[89969.019903] 3w-9xxx: scsi2: AEN: INFO (0x04:0x0029): Verify started:unit=0.
[104242.396032] bttv1: timeout: drop=212 irq=7904826/7904826, risc=36ba403c, bits: HSYNC OFLOW
[135992.577078] 3w-9xxx: scsi2: AEN: INFO (0x04:0x002B): Verify completed:unit=0.
==> /var/log/zm/zmdc.log <==
06/25/11 17:57:06.051920 zmdc[1807].INF ['zma -m 1' starting at 11/06/25 17:57:06, pid = 4856]
==> /var/log/zm/zmwatch.log <==
06/25/11 17:57:05.172619 zmwatch[1876].INF [Restarting analysis daemon for Monitor-1, time since last analysis 9 seconds (1309039025-1309039016)]
06/25/11 17:57:06.085892 zmwatch[1876].INF ['zma -m 1' starting at 11/06/25 17:57:06, pid = 4856]
06/25/11 17:57:06.088930 zmwatch[1876].INF [Restarting analysis daemon for Monitor-2, time since last analysis 8 seconds (1309039025-1309039017)]
06/25/11 17:57:06.799844 zmdc[1807].INF ['zma -m 2' starting at 11/06/25 17:57:06, pid = 4860]
06/25/11 17:57:06.832262 zmwatch[1876].INF ['zma -m 2' starting at 11/06/25 17:57:06, pid = 4860]
06/25/11 17:57:08.639240 zmdc[1807].ERR ['zma -m 1' exited abnormally, exit status 145]
06/25/11 17:57:09.319385 zmdc[1807].ERR ['zma -m 2' exited abnormally, exit status 145]
06/25/11 17:57:16.836582 zmwatch[1876].INF [Restarting analysis daemon for Monitor-1, time since last analysis 8 seconds (1309039036-1309039028)]
06/25/11 17:57:17.485872 zmdc[1807].INF ['zma -m 1' starting at 11/06/25 17:57:17, pid = 4865]
06/25/11 17:57:18.235202 zmdc[1807].INF ['zma -m 2' starting at 11/06/25 17:57:18, pid = 4869]
06/25/11 17:57:17.524560 zmwatch[1876].INF ['zma -m 1' starting at 11/06/25 17:57:17, pid = 4865]
06/25/11 17:57:17.527613 zmwatch[1876].INF [Restarting analysis daemon for Monitor-2, time since last analysis 7 seconds (1309039036-1309039029)]
06/25/11 17:57:18.272526 zmwatch[1876].INF ['zma -m 2' starting at 11/06/25 17:57:18, pid = 4869]
06/25/11 17:57:20.076670 zmdc[1807].ERR ['zma -m 1' exited abnormally, exit status 145]
06/25/11 17:57:20.748997 zmdc[1807].ERR ['zma -m 2' exited abnormally, exit status 145]
Once I restart the server or even just zm service it starts recoding again, for a while.
mastertheknife
Re: Randomly not recording
Post by mastertheknife »
Seems zma is lagging behind and can not keep up with the rate of zmc. Try slowing down the capture or speeding up the analysis.
mastertheknife
Kfir Itzhak.
joako
Post by joako »
I am using mode: "record" w/o any analysis. So even to record w/o motion I need faster hardware?
mastertheknife
Ok, seems like something else is the issue then.
Please enable debugging level 9 and post a debugging log for zma.
mastertheknife.
Kfir Itzhak.
joako
Post by joako »
I fix the issue by deleting all the events and starting over.
But now my 2nd system does the same?
How can I ensure recording continues without deleting everything? It sort of defeats the purpose of recoding.
joako
Post by joako »
no matter what i do on this system it always goes back to not recordidng.
how can i ensure it records at all hours without fail?
TucsonDirect
Post by TucsonDirect »
Try the zmlarch Live Cd.
Just remember to edit the hosts file so the server will start
