Drive 100% full crashes zm
eronquillo
Post by eronquillo »
Hi everyone. We are not able to start zoneminder after the drive went 100% full. After manually removing some events, we repaired all tables in the zm mysql zm database. Then we tried "service zoneminder start", giving us this error message:
Bareword "ZM_DYN_DB_VERSION" not allowed while "strict subs" in use at /usr/bin/zmupdate.pl line 430.
BEGIN not safe after errors--compilation aborted at /usr/bin/zmupdate.pl line 612.
Zoneminder will not start up because of this. Does anyone know of a solution to this? Thanks!
clipo
Post by clipo »
ZM crashes when ever your drive is full, have you deleted all of the images from the images folder and followed and hence emptied your drive then do the database repair procedure.
http://www.zoneminder.com/wiki/index.ph ... atabase.3F
