Too many open files in system
help40
Post by help40 » Sat Nov 20, 2010 10:55 am
I am getting this error message in apache logs
"Too many open files in system"
is it related to zoneminder ? or not ?
any resolution?
jdhar
Post by jdhar » Sat Nov 20, 2010 6:20 pm
I think it's related, but I don't know the answer... reason being that I started getting this after in stalling ZM too, and haven't figured out. I just have to reboot every few days :(
eyeZm, Native iPhone App for ZoneMinder: http://www.eyezm.com
Version 1.3 now available on iTunes, introduces Montage view, HTTPS/SSL support and H264 native streaming!
Subscribe to RSS feed for updates: http://www.eyezm.com/rssfeed.xml
help40
Post by help40 » Sun Nov 21, 2010 12:03 am
I definatelly do not like to be babysitter of my Zoneminder ...
The problem is when someone watch monitor for too long ...
the file descriptor of the system by default is 1024
you can see it with
# ulimit -a
I hope I found the answer , I am testing it now ....
editing
apachectl (mine is here - /usr/sbin/apachectl )
and adding
ULIMIT_MAX_FILES="ulimit -n 16384"
you can also take a look here, where I found this answer :
http://serverfault.com/questions/20183/ ... -in-system
timcraig
Post by timcraig » Sun Nov 21, 2010 4:05 am
Zoneminder uses alot of open files when it's using mapped memory.
Linux has a set limit of how many files that can be opened at the same time. You can see the current limit:
cat /proc/sys/fs/file-max
To change the max, you can edit the /etc/sysctl.conf. So for example, your current max is at 5000 and you want to change it to 10000. You add the line to your /etc/sysctl.conf file:
fs.file-max = 100000
To make the change go into effect, you then run
sysctl -p
help40
Post by help40 » Mon Nov 22, 2010 12:24 pm
so You suggest increasing to 100 000?
by the way this file is not present by default in Slackware , but I read that
"if you create that file /etc/sysctl.conf yourself, then slackware will automatically run "/sbin/sysctl -e -p /etc/sysctl.conf" everytime you boot."
timcraig
Post by timcraig » Mon Nov 22, 2010 10:06 pm
I increasing the file max to double the size of your current amount.
So if "cat /proc/sys/fs/file-max" returns n
Set the max to 2n
If the /etc/sysctl.conf file doesn't exist go ahead and create one.
I should have mentioned that you'll only need to run sysctl -p just to make the new settings in sysctl.conf go into effect without needing to reboot the computer. You won't have do call that program everytime you computer starts up.
help40
Post by help40 » Tue Nov 23, 2010 12:00 pm
I will test it , I am not sure this one will help
ulimit -n still show 1024 after that
Users browsing this forum: No registered users and 5 guests
