Just wanted to let others know, that it works with openSuse 11.3 64bit (kernel 2.6.34) and zm 1.24.2 (current rpm with packman libs, I used the one-click-install link).
USB VendorID:ProductID = 17ef:480f
Manufacturer: Chicony Electronics Co., Ltd.
Only problem was finding the right parameters for the monitor source:
Device Path /dev/video0
Capture Method v4l2
Device Channel 0
Device Format PAL
Capture Palette YUYV
Capture Width (pixels) tried 320, 640, 1600
Capture Height (pixels) tried 240, 480, 1200
Preserve Aspect Ratio off
Orientation Normal
