Jumpy/glitchy picture.
cilione
Post by cilione »
Using a 10$ PICO2000 clone, bttv card=77.
Port 1 works just fine, it's just that if I connect two cameras to the card, one of them gets glitchy/jumpy. I've checked cables on both cameras by plugging them in one at the time, no errors.
Hardware or software problem?
Cameras running at 384*288 (PAL B, RGB555, 10 fps).
Shared memory: 128MB.
Cameras:
http://www.dealextreme.com/details.dx/sku.15756
PCI-Card:
http://www.dealextreme.com/details.dx/sku.15758
bb99
Post by bb99 »
Try changing your CAPTURES_PER_FRAME value to 2 or 3.
Skid
Re: Jumpy/glitchy picture.
Post by Skid »
@bb99, I love you. I been fighting with this issue for weeks.
bb99
Post by bb99 »
Hopefully a value of 2 worked for your card keeping your total throughput to 15 fps.
marjanko2
Post by marjanko2 »
For me didn't worked, any other suggestion, i ahve a 4ch easy cap, and same camera.
bb99
Post by bb99 »
Next step to try is to disable "options::config::V4L_MULTI_BUFFER" by unticking and restarting ZM.
Pure L
Post by Pure L »
bb99 wrote:Try changing your CAPTURES_PER_FRAME value to 2 or 3.
This worked for me!
Changed it to 3 and all's well.
