Hy
I'm searching for a IP-Cam for outdoor (mount on wall) that is compatible to zoneminder and also payable.
I found the PC140 from Sony @ camsecure, is this one compatible or do you have any suggestion in the price range till 150EUR.
My lady preferes the DOME cams but I cannot find any with IP66, zoneminder compatible & payable beside the SK-720C-IP... but it`s 200 EUR...
requierement:
- picture of course not to bad
- low power consumption or sleep mode if no motion
- IP-RJ45
- outdoor
- view range is just 2-10m
decision guide for IP66 IP VIVOTEK IP7330
Vivotek IP7330
You probably figured this out by now, but for others:
My Vivotek ip7330 is working fine with zoneminder. Its a nice little camera, although don't expect much for night vision sensitivity/noise.
The zoneminder setup is:
General:
Source Type: Remote
Source:
Remote Protocol: RTSP
Remote Method: RTP/RTSP
Remote Host Name: your.ip.addr.es
Remote Host Port: 554
Remote Host Path: /live.sdp
Capture Width (pixels): 640
Capture Height (pixels): 480
On the camera side it all camera defaults:
Authentication: disable (its on my LAN)
Access name for stream 1: live.sdp
RTSP port: 554
etc
I'm just running at 2fps, as this is enough for normal motion detection. No need to see someone winking at the camera
General:
Source Type: Remote
Source:
RTSP port: 554
etc
