Hi guys,
I didn't search the forums coz I don't know how I should describe my problem to you.
Since shortly recorded events seems to show up with a minut record time (event every minut); before an eent lastest 10 minuts.
I didn't change any configuration and didn't directly see what setting could cause zoneminder the record for 1 minut and then start new event.
Do any of you guys have an idea what is wrong or what needs to be changed?
Thx
Weird stuff
I did try that ... nothing changed ... after looking more into it I saw that every event off 1 min lenght had 0 frames ...
My hdd was at 1% used space; so i suppose it must be the amount off files causing problems (I have over 140000 events for 3 cameras) ...
Still deleting them ... is there a way to delete all events @ once? Filter gives memory error
I ll keep you guys posted afterwards
I Manually deleted all pictures from the event directory but even after several hours they amount on zoneminder main window only dropped 20 Ã 30 events ...
Even weirder if you ask me
Even removing cameras themselves gives me:
Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 16 bytes) in /home/zm/public_html/includes/database.php on line 125
